wideband v's narrowband afr
In simple terms cos I'm simple lol why should I fit a wideband afr instead of a narrowband afr?
Cheers!
Cheers!
IIRC, narrowband shows anything around Lambda 1 as stoich, anything richer rich, and anything leaner lean
But obviously doesn't tell you how rich or lean. And obviously in power enrichment, it would show rich all the time, but you need to know HOW rich, so actually have a figure, of 0.8 lambda or whatever. And obviously in that instance it wouldn't be considered as rich, so is technically incorrect
Well as was thinking initially that the narrowband I've been offered would give me a warning of it running lean so at least you have a indication that you need to back off and investigate, but now I'm looking into it more it seems sense to go WB?!
*** Sierra RS Custard ***
A narrowband gauge will show "MAXIMUM RICH" at 14:1 AFR, lean enough to melt your engine.
As Jim says, worse than useless IMHO as its actually lieing to you when you're on boost essentially, telling you everything is ok when its not!
Its what the NARROWband bit refers to basically mate.
Essentially they work as follows (exact numbers vary a little, but not much):
14.5 or lower = fully rich
14.5-14.7 = rich
14.7 = stoich
14.7-14.9 = lean
14.9 or higher = fully rich
Just no use at all for anything other than running a car in closed loop, ie the thing they are intended for!
They were NEVER meant for a gauge for human eyes in the first place.
14.5-14.7 = rich
14.7 = stoich
14.7-14.9 = lean
Its a few years since Ive personally bought an in car gauge as I normally use handheld ones so not sure what the best option at the moment is really TBH for an in car gauge. Innovate DB1 was the last one I bought though and thats been great.
Any of the innovate stuff tends to be pretty reasonable value for the money though IME, but obivously as its using the cheap bosch sensor you have to accept changing it once a year or whatever so you'll see people moaning about that if you look around.
Same applies to pretty much all the cheaper ones though as far as im aware, as they are nearly all based around that same sensor.
But with all these gauges like the innovate/stack/aem the values are going to vary slightly depending on sensor condition and how recently it was calibrated etc, so testing one of each doesnt really tell anything useful TBH as if you tested another one of each they could be the other way around next time.
They're all close enough to be useful for what Lee is after though.
Ive compared several innovates now to the same Autronic that Mark uses (because its the same on the dyno dynamics rollers and ive had several cars with innovates on those rollers when mapping them) and they have all been well within half of an AFR so far. In fact most are within 0.1
For road use by an end user, I personally think that anything within 0.5afr is perfect. However, there is a pre requisite to this advice...
I advise you buy a decent one, then have a reputable tuner check your engine and setup out under load to ensure its safe, ideally someone who likes to expend Ł500+ every few months on new NTK sensors (Not cheap Bosch ones) and then if they tell you your in car gauge is XYZafr out, great, you know where you stand as all you really want to know is if it suddently looks wrong compared to how it was when your tuner pronounced it good.
Gauges are only really good for their ability to confirm things are as they were last time you checked, especially if the numbers dont mean much to you.
is 12.5afr ok for my engine? Totally up to your tuner, so just find out what it SHOULD read, and worry when it stops doing so.
[quote=Lee Reynolds;5881809]That makes sense Stu. Cheers
So would this be what Im looking for?
http://www.ebay.co.uk/itm/AEM-Wideba...979[/quote]
thats the kitty, available direct from the states though for Ł130 last time i checked.
my car runs 11 on tdis ŁŁŁŁ worth of equipment and shows as 11.4 on my aem so i know true is 0.4 richer than my gauge, when i was down to one fuel pump it showed me instantly it was lean by dropping to 16 afr as soon as i hit any boost and of the scale to 3 dashes when i floored it. essential for any turbo car.
wheelwizardrefurbs
22-09-2015 05:45 PM
