mtx75 gearboxes
Old Feb 27, 2005 | 05:18 PM
big_wig_074's Avatar
big_wig_074
Default mtx75 gearboxes
are these all pretty similar stregth wise? for a turbo conversion obviously,is the rs2000 item stronger than a xr3i version? cheers!
Old Feb 27, 2005 | 05:38 PM
big_wig_074
anybody?
Old Feb 27, 2005 | 05:40 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
NO
DUST !!!!!!!!
Old Feb 27, 2005 | 05:49 PM
MK5RST's Avatar
MK5RST
The rs2k and xr3i 130 ps box are the same and they are much stronger than the RST box but done have LSD, im running one, u need a funny clutch for it i think i got a galaxy v6 automatic clutch plate
Old Feb 27, 2005 | 05:51 PM
scort's Avatar
scort
Glaxy V6 automatic clutch plate???
You jest?!!
lol
Old Feb 27, 2005 | 06:07 PM
big_wig_074
radleigh you geek!
Old Feb 27, 2005 | 08:10 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
if you run with 3 shafts you wont need a LSD
Old Feb 27, 2005 | 08:15 PM
MK5RST's Avatar
MK5RST
scort, no jest mate, honestly it was the only clutch o could find with a 21 or 24mm input spline and 220mm plate!!!!
Old Feb 27, 2005 | 09:34 PM
scort's Avatar
scort
But automatic cars use a flywheel and a torque converter bolted directly to it,
Automatic cars do not use a clutch plate,
Steve
Old Feb 27, 2005 | 09:38 PM
MK5RST's Avatar
MK5RST
Lol, it was listed as an automatic clutch, i just used the plate, it was the only one i could find, its pretty strong though
Old Feb 27, 2005 | 09:43 PM
scort's Avatar
scort
Typical bloody part listings!!
Jano, thats an interesting statement. What makes you say that? I'm sure it reduces the torque steer a bit. But does it make that much difference?
Whats the diff up to? In terms of torque?
Steve
Old Feb 27, 2005 | 09:56 PM
Paul J's Avatar
Paul J
Hows that then Never give the benifits a proper diff does
Old Feb 27, 2005 | 10:43 PM
Versus_Creations
Ask me a question!
A pinto AP 4 paddle is direct fitment for these boxes (MTX75) Diesel Pressure plate and release bearing works fine with 317bhp
Is this a question or a statement
I take it you know this from experiance then yeah??
The reason for a 3 piece shaft is the value for money over a Ł500-1k diff and the results will work out better!! Instead of the expensive diff you fit 3 shafts.
Fact is with equal length shafts you WILL reduce/eliminate tourque steer with a well balanced car and suspension!! Fords used this system on 909 RS2000 and other Private teams also used the MTX75 in a FWD (S1, Puma & a few others i know of) with 3 piece shafts. Dont under estimate the setup.
Regards
Jano
Old Feb 27, 2005 | 10:56 PM
gearboxman's Avatar
gearboxman
The RS2000 championship cars all had Quaife ATB's fitted
you will reduce/eliminate torque steer with a well balanced car and suspension, equal length driveshafts will help....
Old Feb 27, 2005 | 11:01 PM
Versus_Creations
Ask me a question!
+ 3 piece shafts
Unless you have spare cash, A decent backing or alot of power i dont see the point in the diff if you have the 3 piece.
Only my opinion of course
Regards
Old Feb 27, 2005 | 11:08 PM
gearboxman's Avatar
gearboxman
+ a well balanced car and suspension
Versus_Creations
Ask me a question!
I spose you must have one of these "proper diff's" then??
Old Feb 27, 2005 | 11:11 PM
Paul J's Avatar
Paul J
Yes thanks, Bernie fitted it to my MTX75
Old Feb 27, 2005 | 11:12 PM
Versus_Creations
Ask me a question!
Yep dam right atm im missing at least 5 of the above
Old Feb 27, 2005 | 11:15 PM
Paul J's Avatar
Paul J
One benifit of the diff is that when cornering and weight is transfered to the outer wheel more power can be transmitted to it and thus reduce the chance of the inside wheel spinning up and lossing drive. How exactly does your drive shaft do this?
Old Feb 27, 2005 | 11:28 PM
Versus_Creations
Ask me a question!
3 piece shaft dont do this!! But good drivers skills will Use "that" weight transfer to your advantage.
You will have to be pushing sum serious power.... which i know your car and my own car is not pulling To have the need for a LSD (If you have 3 piece)
If it fails after having 3 piece shafts you can always pay the extra and get the diff, but you wont need it .
Its oviously different for your setup as you have the diff already, but that dont matter. Even YOUR car will benifit from the 3 piece shaft setup
HTH
Regards
Jano
Old Feb 27, 2005 | 11:37 PM
Paul J's Avatar
Paul J
The triple shaft im sure is a good idea but disregarding cost which would you prefer.
I also totally disagree with the power statement, ask any 205 challenge driver
Driver skill is all good and well but it cant overcome the laws of physic's and the fact a diff will enable more power to be put down when the car is pitched.
Old Feb 28, 2005 | 12:06 AM
Versus_Creations
Ask me a question!
disregarding cost.
Disregarding cost i would have both As the 909 setup!
BUT you keep comparing the system with yours
In my case i need to make driveshafts any way as the std items you have will NOT fit a mk3/4 escort , for this reason.. I would rather make the 3 piece (As this is better) than making the 2 piece which is also making it have more rotaitional twist which could break the shaft in extream cases. (I have seen this)
Dont get me wrong TAZ has the same as yours and there is no need for him to pay extra to change the std items..
So the outcome for you is stick with what you got as it all bolts up std.
For the mk3/4 boys.....only 1 way to go
Regards
Jano
Old May 19, 2005 | 10:05 PM
Versus_Creations
Ask me a question!
As we are on gear box talk, i thought this topic was very interesting and had good info
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
