Help - fitting Focus roof bars!
Old Apr 8, 2012 | 01:26 PM
RichieST's Avatar
RichieST
Default Help - fitting Focus roof bars!
Hi all
Am trying to fit a set of genuine Ford roof bars to my Focus. I've got all the hardware but they are second hand and came with no instructions.
I've removed the plastic covers on the plastic rails on the roof and was expecting to see some bolt holes underneath to screw the bolts in to, but there doesn't appear to be, there's just a thick bead of painted over sealant Don't really want to go digging bout in the sealant to find the bolt holes in ase they aren't there!
Anyone done this before and know what I'm doing wrong?
Rich
Old Apr 8, 2012 | 08:35 PM
Dunccoss's Avatar
Dunccoss
They are under the painted sealer in the centre
Old Apr 8, 2012 | 09:24 PM
paulmex's Avatar
paulmex
Just done the same thing to mine and it's like Dunccoss said. I used a small flat blade screw driver and dug the sealer out carefully to find the cross head blanking plug that's under there ! Don't know if its me been paranoid but when I take the bars off now I fit a stainless button headed Allen bolt with a smidge of grease and a small rubber gasket/seal in all 4 of the holes before a put the plastic covers back on ! The reason been the covers aren't water tight and the hole you have to dig out makes a perfect puddle for water to sit in probably wouldn't cause any trouble but I just thought it was a crap idea !!!
Hth paul
Old Apr 8, 2012 | 09:29 PM
RichieST's Avatar
RichieST
Thanks for the replies guys, went digging with the screwdriver earlier
What an utterly crap design by Ford, I will definately be plugging the holes up properly when I remove the bars. Don't suppose you know the thread size for the bolts do you?
Old Apr 8, 2012 | 09:33 PM
paulmex's Avatar
paulmex
Sorry cant remember if they were 5mm or 6mm? I had some kicking about in my box so just used them
Old Apr 9, 2012 | 04:36 PM
Dunccoss's Avatar
Dunccoss
Just squirt some Silcone sealant over the holes when you remove the bolt as that will stop any water getting in plus you can just pull it out easy if and when you use them again
But agree crsp design
Old Dec 11, 2013 | 07:20 PM
nomic's Avatar
nomic
Angry ford focus estate
i have a ford focus estate 99
there is no roof bars or roof rack on the car and the rubber seals along the roof gutter do not have any removable sections where you would normally attach the roof rack anyone got any ideas of how you install a roof rack to this car ?
Old Dec 11, 2013 | 08:12 PM
GingeRS2K's Avatar
GingeRS2K
Open door, pull top rubber seal should be a plastic screw there. My MK2 mondeo of same year was same and my mk4 is too.
Old Dec 11, 2013 | 09:15 PM
nomic's Avatar
nomic
Default thanks
ok will do that thanks matey
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
neil18
Mar 14, 2016 01:08 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
