Weird missfire problem.
Old Apr 8, 2012 | 08:23 AM
BRAM's Avatar
BRAM
Default Weird missfire problem.
Hi as above on a rs turbo zvh with haltech management when you start the car from cold and let it idle it will idle for a little while ok and then start to miss but if you pull the ht leads off the plug and just rest it ontop of the plug it will run great and wont miss the car drives perfect and idles perfect but if you plug it back on it will miss again, any ideas?
Ive tried new msd leads and 3 diffrent sets of plugs and makes no differance so dont think its anything to do with these
Old Apr 8, 2012 | 09:30 AM
Weird. I would of said it was plug leads too.
Is the spark earthing out on the head.Are you still running a dizzy or is it now coil pack. Might be worth swapping dizzy/coil pack???
Old Apr 8, 2012 | 09:46 AM
BRAM's Avatar
BRAM
Running coilpack mate, can't see it arking onto the head.
We thought it was the leads so bought new ones from msd and its still the same.
Old Apr 8, 2012 | 09:56 AM
Its very strange isnt it. Has it just started to do it.
Old Apr 8, 2012 | 09:58 AM
BRAM's Avatar
BRAM
No its done it for a while now but just recently got it back out on the road and wanting to get all little problems sorted
Old Apr 8, 2012 | 09:59 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
what is your ignition adder for ect
Old Apr 8, 2012 | 10:03 AM
BRAM's Avatar
BRAM
Sorry mate dont know what you mean
Old Apr 8, 2012 | 10:07 AM
Turbosystems
Super Moderator
you need to advance the ignition when it's cold this uses the engine coolant sensor
there should be a specific table for this in your haltec software
there should also be one for air temperature but this one is normally just used to retard with high act
Old Apr 8, 2012 | 10:10 AM
BRAM's Avatar
BRAM
Ahh Right now i know what you mean, i will have a look at it see if i can sort it out Thanks
So i should try advancing the timing in the coolant map see if it makes any difference
Old Apr 8, 2012 | 10:51 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I've noticed on standard rs turbo's if its got a fouled plug if you pull the lead back off the plug it appears to boost the spark and it then runs on that cylinder, fit the lead back on and nothing...never worked it out. weird.
Old Apr 8, 2012 | 10:57 AM
BRAM's Avatar
BRAM
Yeah thats what its like
Old Apr 8, 2012 | 11:19 AM
S1's Avatar
S1
Sounds like the plug is fouling, it may be the heat range is wrong and you need to run a hotter plug to keep it clean or possibly one cyclinder is oiling up due to worn rings? Have you done a compression check across all cylinders?
Old Apr 8, 2012 | 11:22 AM
Turbosystems
Super Moderator
noo nooo noooo
you need to post your main ignition table and your ect advance table and we will see if there are any areas that are dodgy
you can det an engine off boost as easy as on boost
Old Apr 8, 2012 | 12:18 PM
BRAM's Avatar
BRAM
No mate havent done compression check but dont think it will be that as the engine hasnt long been built, but will check thanks
Old Apr 8, 2012 | 12:20 PM
BRAM's Avatar
BRAM
noo nooo noooo
I will try to find out how to post the maps up so you could have a look before i touch anything thanks
Old Apr 8, 2012 | 12:21 PM
Turbosystems
Super Moderator
would it be easier for you to email them to me then
Old Apr 8, 2012 | 01:32 PM
BRAM's Avatar
BRAM
Yeah mate that would be good I will do that when I get back home. Cheers
Old Apr 8, 2012 | 01:57 PM
vroooom ptssssh
It Wasnt Me!
It's probably just needing the map sorted...
Old Apr 8, 2012 | 03:00 PM
BRAM's Avatar
BRAM
Yeah mate thats what im thinking.
Old Apr 9, 2012 | 05:53 PM
Turbosystems
Super Moderator
definitely needs mapping professionally
Old Apr 9, 2012 | 07:51 PM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
i'm having similar prob at the min, have changed everything in the ignition system, plugs, leads, coilpack, had been running sweet, but last week or so its developed a miss low down in the rev range, but once the revs are up, its fine.... but just as you press the go pedal, it misses.....
i should also add its all standard, apart from an exhaust system and a forged bottom end, though i haven't up'd the boost, staying standard boost level....
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
