Help on crank sensor types ie hall sensor effect???
I have 2 crank sensors to choice from on my race car and wanted to know what the difference is and what advantages?
There is a hall effect sensor (3 wires)
or inductive pickup (2 wires)
can someone advise please
Most cars use the Inductive pickup, or variable reluctance sensor as standard these days as they are very cheap to produce. They are not powered and generate an AC voltage where the frequency and amplitude increases with RPM. They are susceptible to noise and need to be well shielded with good signal conditioning in the ECU. Cossie, Zetecs etc etc all use this type.
Hall effect are an active sensor, i.e. is powered usually by a 5v signal. These return a nice 5v square wave to the ECU, frequency increases with RPM. Given a choice starting from scratch I would use the Hall Effect.
Rick
Rick
Although as Rick says, 2 wire Mag sensors are more susceptible to noise, simple solution to that is dont fuck the wiring up.
chowfornow
14
05-01-2019 09:01 PM
