cambelt change on a mk1 focus
changing my cambelt on my 1999 2.0 mk1 focus, but cant find how so set crank pulley. read that there should be a bolt that you remove on the back of the engine, but cant find this bolt anywhere. its an early engine with 3 pulleys in the cambelt kit. any help would be great.
think its 75mm long stud threaded into block, stops the crank weight from turning, there is a m8 plug in the block wall lower r/h/s, you can buy the tool or make 1,
im in wickford, quite away from Sudbury, but cheers anyway. the problem was one of the pulleys had come apart and belt was running on the bearing, it had cut right throught the belt. was so lucky it hadnt snapped. otherwise would have marked everything before removing it.
saph in dorset
14-08-2015 10:10 AM
track.focus'd
12-08-2015 05:53 PM
