Remove focus steering wheel help
Old Mar 9, 2012 | 07:22 AM
Andy Tucker's Avatar
Andy Tucker
Welsh And Proud
Default Remove focus steering wheel help
So my mate is scraping his 5dr focus and Has asked me if I want anything from it.my steering wheel is warn bad so I will swap.
But how do I get the steering wheel off?
Thanks,Andy
Old Mar 9, 2012 | 07:27 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Disconnect the battery
Leave for 10 mins
Behind the steering wheel will be 2 bolts holding the air bag in place
Turn the wheel to access them
They won't come out all the way but when they are out you can pull the airbag off
Unclip the wiring
Remove steering wheel as normal
Undo the big but in the middle
Leave it in by a few threads though
Bang wheel from behind with the palms of your hand until its loose
Remove nut fully
Swap wheel
Old Mar 9, 2012 | 07:41 AM
Andy Tucker
Welsh And Proud
Top man dojj.thank you sir.do you happen to know the size of the centre nut and the 2 at the back?
Old Mar 9, 2012 | 07:45 AM
STeve's Avatar
Super Moderator
if it like other steering wheels with airbags it will be a 5.5 bolt on the back and a 15/17 on the steering wheel, also some models require you to turn the key one click to release the steering lock to remove the wheel
Old Mar 9, 2012 | 07:57 AM
dojj's Avatar
dojj
As per steves post, but some cars have normal bolts and some cars had torx head bolts so go prepared
And take a long breaker bar with you as the big nut is sometimes a bit tight
Old Mar 9, 2012 | 08:17 AM
Andy Tucker
Welsh And Proud
Ok cheers guys.will let you know how I get on 
Old Mar 9, 2012 | 08:44 AM
I just changed our focus steering wheel a few weeks ago. The bolts are defo 5.5mm. you will have to disconnect the air bag from the squib.
I fitted my original air bag to the newer steering wheel and now when pressing the horn you have to really press on the air bag for it to work.
Old Mar 9, 2012 | 09:01 AM
Andy Tucker
Welsh And Proud
Oh don't say that now.
Old Mar 9, 2012 | 10:05 AM
Iain Mac's Avatar
Iain Mac
I'd use the bag that matches the wheel and, if he's scrapping the car, keep both his and your airbags until all is in and working.
Old Mar 9, 2012 | 02:33 PM
The new steering.wheel come.with an air bag. That air bag fits the old steering wheel ok but the original air bag fits the new steering wheel ok but the horn is a bit hard to push. Stupid thing.
Old Mar 9, 2012 | 05:09 PM
nevsrevs's Avatar
nevsrevs
its a big torx that hold the wheel on
Old Mar 9, 2012 | 05:21 PM
Andy Tucker
Welsh And Proud
i thought it was a 24mm nut
Old Mar 9, 2012 | 05:22 PM
Andy Tucker
Welsh And Proud
gonna swap the boot lids over to as mine has a small bit of rust on the bottom corner and his is mint
Old Apr 20, 2014 | 05:32 PM
dahipster's Avatar
dahipster
Hi all,
Picked up this thread as I was changing my steering wheel too. Instructions were perfect, had no problems getting old one off and new one on, cheers for your help.
However, now I've got a problem... as soon as I reconnect the battery, the horn wont shut the f**k up!! I unscrewed the airbag, but left it plugged in, then reconnected the battery, and it didn't go off. Swapped back to the old steering wheel and same result... still goes off.
Can anyone suggest what I've done wrong?! Thanks.
Old Apr 20, 2014 | 05:51 PM
dojj's Avatar
dojj
The horn push is on 2 metal tracks inside the wheel
If the switch hasnt been put back properly they will short out across the tracks causing the horn to constantly sound
Old Apr 20, 2014 | 06:20 PM
user 628729's Avatar
user 628729
You do have to be careful seating everything properly or you get problems with the horn as noted above.
I had mine swapped a while back to fit cruise control and the horn was "wrong" until we took it all off and redid it carefully.
But yes, it's just two nuts (5.5mm sounds right) behind to release the airbag, plugs into the clock spring and a great big hexagonal nut in the middle.
Old Apr 22, 2014 | 04:54 PM
dahipster's Avatar
dahipster
I've attached links to a couple of pics, one of the steering column without the wheel attached and one of the back of the airbag as I think its in one of these places I'm causing the problem. would you mind just being a little more specific on what needs seating properly?
Thanks again guys
https://dl.dropboxusercontent.com/u/...2017.16.17.jpg
https://dl.dropboxusercontent.com/u/...2017.16.29.jpg
Old Apr 24, 2014 | 09:14 AM
Farmer Giles's Avatar
Farmer Giles
make sure you don't turn the ingintion on while the air bag is off or else you'll throw the air bag light on and you'll probably have to get it plugged in to turn it off.
2p
Old Apr 24, 2014 | 09:51 AM
user 628729
I can't really as I was watching and helping someone else do it.
I think it was about the precise seating of the clock spring and how the airbag section then fitted over that. Something needed to click positively into place.
But on my car the clock spring was swapped at the same time, so if yours isn't disturbed at all that may not be it.
Old Apr 25, 2014 | 09:18 AM
IanC's Avatar
IanC
Only advice I can give is make sure your steering lock is on when you take your steering wheel off as the steering columns can drop down and there a pig to get back up again
JoeyBoyden
Jan 4, 2024 02:36 PM
RockinRein
Aug 19, 2015 07:08 PM
Roosie
Aug 19, 2015 11:52 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
fatboy billy
Aug 3, 2015 08:34 AM
