Can someone help me asap
I have a 53 focus 1.6 with 85k on clock.
Just noticed tonight that when she is warm it miss fires underload ie 3rd gear with foot down
It back fired once as well
I had cam belt changed 300 miles ago, since having it done i havnt floored it as i wanted to bed it in
Could it be connected or is it coincidence?
Location: In the pub cheering on Ricky hatton and Joe calzaghe
Cam timing is one tooth out by the sounds of it mate...if it was the coil it would do it all the time mate and in many gears
My dad had a similar problem with his focus, and it turned out to be the speed sensor.
My speedo did act up the other day, it drop to 0 5 times whilest driving
Could this be linked?
Il get it checked out,
Since iv had the belt done its felt loads better to drive and its been better on fuel
It drives spot on all the time apart from when you put the engine under load i.e if you go up a hill and put your foot down, it just coughs and slutters
I would go with coil first the wife's mk2 mondeo ran fine till you gave it a bit of stick then after 3000 rpm it would misfire like mad changed the coil and never had another problem
Fudgey
21-07-2004 10:11 PM
