Where can I get siemens 83 lb injectors?
They have not been available for a little while now, we managed to grab the last of the stock, so have had a supply for longer than most people have.
Be aware some people are selling an injector which they think is the 83lb we use, but its far from it, and if you use these with one of our chips it may cost you an engine.
I have had a few cases where they have been used with our chips already.
I guess this is what you get when you buy from people who do not know what they are selling.
We are working on a replacement as we speak.
I got mine from the states in the end.
Have a look here and see if theyre the right type
http://www.fiveomotorsport.com/impor...uel-injectors/
Not naming names, you know thats not my style... but there is at LEAST two members on here that got stung this way, one lost his GT30 engine due to it too, so maybe they would like to tell people.
1st to 200 without NOS
I forget the part number top of my head but James is right, there are a couple of traders in the cossie game selling "83lb blacks" injectors that are NOT substitutes for the 3105 chassis that most of us base our chips on.
Yeah... maybe that is it.
Take care out there people... if your buying injectors to suit a chip, ensure the injectors PHYSICAL PART NUMBER is the EXACT same one as the chips supplier gives you.
If its been "removed" or "Doesnt have one" then send them back.
All injectors have part numbers. LOL
Regarding the injector type?
I think it would matter very much, if you spent Ł300 on a set of injectors, then found out that they are potentially not compatible with your engine/inlet design or ECU.
Because then you have to buy new ones that will work, in order for the mapper to complete his job.
You must share the view of the people selling them
I havent tested them, so cannot coment on how they work
but how would you guess the spray formation of the multi nozzle will work on a YB inlet/head? are they the correct resistance?
They may fit and run, but thats far from meaning they are suitable.
Really? Its obvious that you have not tried various multi nozzle injectors in a YB to see what happens, and thats aside from the fact the injectors coil impedance may be wrong for the ECU you own, and you cant map round that either. LOL.
With all due respect, perhaps you shouldnt advise people upon it until you have as you are in this case very wrong... James has touched upon why, and he has never even tried. Unlike myself who has tried a lot of them.
Has the person selling them tested them? Becuse the reports i have seen so far suggest they dont work very well at all.
Its a very risky game, and certainly not one i would be involved in.
The customers certainly were not advised that they were a newer injector that may not work well
it would still matter to me, if i purchased a set of injectors, then found they didnt work.
i`d be very happy my engine wasnt dead, but still a little upset i`d wasted Ł300 on a set of injectors that were not suited to my engine.
All we are saying is BE CAREFULL, and check part numbers dont take someones word for it.
Anyway... Ran has given the only usefull answer to the OP on this topic, check the cars breaking and used parts for sale as at the moment I dont think many people have the original 83s.
If you are having it mapped live, just call up your mapper and have them supply something they want to use. Job done.
At the end of the day its no different to someone putting some green VW Golf injectors in a YB mapped for green 803s. Its the end users fault for not realising that the PART NUMBER is what is crucial, not its name, colour or flow rate.
James just mentioned you should beware, as some people would be trusted to just supply you what you want, without you actually specifying a part number. Chances are, this chap and lady may both just have just said to the YB parts supplier "I need a set of 83lb injectors please" well that is what they got in reality... so they did no wrong, even if we all know damn well he should have checked they werent for a cossie following some pretty standard routine tuning.
*** Sierra RS Custard ***
Not sure why James90RS got so jumped on there, I read his original post as meaning if you are getting your car setup properly then you dont risk killing your engine even if the injectors are wrong as the person setting it up will AFR and Det check it etc, ie it wont matter in terms of "losing a gt30 engine" etc.
Good advice from stu about PART NUMBERS being the key thing though not bloody colour etc!
Stu's point is that people selling them shouldnt be "named and shamed" as all they are doing is selling siemens 83lb injectors and saying they are siemens 83lb injectors, which isnt actually doing anything wrong.
Its the customers who are assuming that means its the same injector that they want despite other differences.
How are these different to the rest then?
