Fan control
Fan control
I have a yb airtec rad and twin fan set up going in my cortina, whats the best way to control the fans coming on and off.
Should i stick with a MSD radiator fan temp switch set up
or
Use my stack pro water temp gauge low & high control out puts.
or
Was just abit woried about reliability and also the gauge will read from the sender in the head, would there be much diffrence in the temp at the two diffrent points.
They should be about the same.
Penty of cars don't have rad switches, they take there temp from a stat housing or the head directly, like your gauge does. That would be the way, if you wanted staged fans.
Rad switch is simply on/off, at least the one your looking at is.
Martin
Martin
Testing the future
i would be tempted to use the stack. i'd have the low settings with the 2 fans wired in series so that they go half speed, and then the high go to paralel wiring for full speed.
it's more to go wrong.
