Does your Ford Focus do this?
Old Jan 31, 2017 | 03:55 PM
  #41
burnzy's Avatar
burnzy
burnzy
My experience with Bristol street has been just as bad and all I was trying to do was return a faulty stat, it's probably still sitting on their shelf along with my money the service manager was an utter ass hole, I wouldn't piss on a Ford dealership if it was on fire.
Old Feb 1, 2017 | 10:16 AM
  #42
BLU's Avatar
BLU
BLU is the new black :)
Battery is 15 mins max as long as you're not paying I would't worry!!
I hope they've done the relevant checks before swapping it....... If they continue to fob you off get yourself to another Ford dealership who are more helpful! Its worth the hassle to travel a bit further if it gets sorted first time!
Old Feb 1, 2017 | 11:31 AM
  #43
rondetto's Avatar
rondetto
10 Year Member
Sorry Blu, battery 15 minutes max. What does that mean?
Old Feb 1, 2017 | 03:25 PM
  #44
gcfcos's Avatar
gcfcos
Ask if they've done a "parasitic drain" test. Simple to do but you'd be amazed at the amount of "mechanics" I've worked with had no idea how to do this lol
Old Feb 1, 2017 | 03:55 PM
  #45
rondetto's Avatar
rondetto
10 Year Member
Ok, what does that do? My neighbour was telling me earlier he had a similar problem with the same garage, his car kept breaking down and the service manager said there was nothing wrong with it. They loaned him a courtesy car and the manager said he would run around in his for two days. He went back to the garage two days later and the manager wasn't there, he had broken down in my neighbours car 10 miles away.
Old Feb 1, 2017 | 05:17 PM
  #46
gcfcos's Avatar
gcfcos
It tells them if there's a massive drain on the battery somewhere. Easy to do, remove earth clamp from battery, put multimeter leads between clamp and battery and set to 10 Amps (or 20 if your multimeter goes that high) and with everything in the car turned off and all doors/boot etc shut u see if there's a drain. 50ma max, ab more and u have a drain somewhere. Next step if u have a drain is to start pulling fuses one by one u till the amp draw on the multimeter drops and there u can see what circuit is causing the drain
Old Feb 1, 2017 | 06:56 PM
  #47
BLU's Avatar
BLU
15 mins, at the most - to change a battery!
Old Feb 1, 2017 | 08:18 PM
  #48
rondetto's Avatar
rondetto
10 Year Member
Oh yes I see now. Thanks for the tips.
jaysoc1
Aug 21, 2015 05:38 PM
taylora1409
Aug 12, 2015 12:06 PM
