ecu diagnostic / obd software
What you got? What's the best out there for reseting eml,air bags and abs ect the one i have on laptop at the moment is ok but strugles with most abs faults.
Thanks
Thanks
Thanks
Im after one (software) for my laptop realy as i already have the lead and other helpful software but might have to invest in one if not as i have been told by a few mates that they are the best
Might help if you first state your budget. And then the marques you intend to work at.
To get decent coverage for a lot of cars will cost a few grand. To get excellent coverage for a lot of cars will cost double that.
And to get dealer level coverage on all marques, maybe treble or quadruple that lol.
Im just an amitor mechanic so all i need it for is what my first post says realy my cheap software does 90% of what i need just would like a bit better it don't always find abs faults.i don't mind spending on software as it pays for its self but on the other hand don't want or need to have the most expensive
thanks
thanks
thanks
thanks
Will they always be right ? of course not.
Will it do ABS or anything else ? No.
So if you want more than basic OBD2 coverage on a variety of cars, you'll need to spend money. And as most car systems are all different, you'll often need a wide variety of equipment to communicate with the various control systems in cars. All marques are not the same, there isnt one machine that does everything, ore remotely close to it.
You could still spend a few thousand, and even on cars it's supposed to cover, still find it lacking.
Here are some places that sell equipment
http://www.ilexa.co.uk/diagnostic-tools.html
http://www.bba-reman.com/content.asp...gnostics_tools
http://www.gendan.co.uk/category_1.html
For example, check out price of IDS (Ford dealer tool) -
http://www.ford-ids.com/uk/start_gbr.html
Can't beat vag-com or VCDS as it's now called for VAG group.
http://www.ross-tech.com/
Engine check pro from Gendan is pretty good (only does engine though)
http://www.gendan.co.uk/product_ENG327P.html
DixieTheKid
14-09-2015 09:04 PM
