looks like compression through rocker breather! what could problem be??
#42
#43
Agreed with Stevieturbo, you really must have the pistons out, if this is happening.
Would bent valves cause that??
an smoke was coming out of the wheel arch which was coming from the oil catch tank so i disconnected the top breather hose to see what looked like smoke/compression pumping out which didnt look right to me.
so i turned it off straight away.
#44
But more to the point...how the hell did it end up with bent valves ? The timing belt must have jumped teeth or something
#45
Chain on the Duratecs, if a timing chain guide/tensioner has failed and then timing slipped you'd expect it to make a noise wouldn't you? Just trying to remember if the cam sprockets are keyed on them, don't think they are. Must be a couple of years since working on a Duratec chain.
edit - http://www.sbdev.co.uk/Duratec/Cams_Springs_Valves.htm
Looks like they aren't keyed, so just held by the bolts.
Has any work been done to the cams when the supercharger was fitted?
#46
no work on cam as far as im aware.
guy told me the chain had been done but no receipt so either lies or maybe a bad job.
i cant explain how it bent valves or understand it myself but thats what has happened.
piston 1
piston 3
couldnt get better pics or more as phone died an no camera to had.
piston 1
piston 3
