what fuel system for 600+ bhp
Old 02-02-2012 | 12:03 PM
Turbosimpsons's Avatar
Turbosimpsons
Default what fuel system for 600+ bhp
what is the best fuel system to use, i'm currently running around 500bhp on a 044 pump, standard saff fuel tank. iv'e just bought a summit racing fuel cell and another 044 pump. will i need a swirl pot ( the summit racing cell has a small sump built in to it) and another pump. thanks in advance.
Old 02-02-2012 | 12:18 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Im shore mad ad is still on one 044 and normal saff tank with well over 600!
Old 02-02-2012 | 12:25 PM
JonnyBravo's Avatar
JonnyBravo
Twin 044's are surely a safe bet.
Old 02-02-2012 | 12:58 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Why don't you ask the tuning God lol
Steve
Old 02-02-2012 | 01:03 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Steve
Thats what i was going to say Steve LOL
Old 02-02-2012 | 01:04 PM
Turbosimpsons
trying to get my post count up.
Old 02-02-2012 | 01:06 PM
Turbosimpsons
that bloody man flue has gone quickly.
Old 02-02-2012 | 02:26 PM
wes's Avatar
wes
If its the same fuel cell i got from summit the sump is only good for drag racing, won't help when your hitting a long right hander for a long time, so depends on what you're going to be using the car for.
In my own setup I use a lift pump (Holley) from the fuel cell into a swirl pot, then to 2x 044's.
Old 02-02-2012 | 03:36 PM
Matt Lewis's Avatar
Matt Lewis
I feel rough as fuck John
Old 02-02-2012 | 06:08 PM
andy escos's Avatar
andy escos
if you go down the fuel swirl pot route i got a new one in the cosworth parts sale section
Old 02-02-2012 | 08:02 PM
Turbosimpsons
Yes wes, same as yours. Where did you get your extra foam from for your fuel cell.
Thanks john.
Old 02-02-2012 | 08:13 PM
turnover's Avatar
turnover
agreed
Old 02-02-2012 | 09:11 PM
Turbosimpsons
I'm defo going to use 2x 044's, looks like I'll need a swirl pot. Just need a lift pump. And some fuel cell foam.
Old 02-02-2012 | 09:28 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
why foam, they deteriorate over time too dont to forget, had loads of problems with my RWD built mk5 escort that turned out to be bad foam fucking the fuel up!
baffled medium size non foam tank, facet/holley/ lift pump or STD cossie pump to feed swirl pot, then twin 044/aeromotive 1000`s to filters to 12mm lines (my choice only mind)
done a few big power customers cars aswell as my own like this
Old 02-02-2012 | 09:32 PM
stevieturbo's Avatar
stevieturbo
C**t
Best system for what exactly ? And how much is 600+ ?
601 would still be fine on a single 044. 600+400 would not.
Whether you need a swirl pot or not depends on the car's usage, and you say you have a fuel cell. Is the design of this not enough to negate the need for a separate swirl tank ?
Outline your exact requirements and it's easier to plan the build. Then draw each item out on a piece of paper along with flow abilities and requirements of any items.
Old 02-02-2012 | 11:54 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Solid advice there stevie !!!
Old 03-02-2012 | 12:01 AM
wes's Avatar
wes
Thanks john.
I ordered it from summit at the same time that I got the fuel cell
I'm sure it is readily available over here
Old 03-02-2012 | 08:19 AM
ian sibbert's Avatar
ian sibbert
Has no one tried the new twin setup from ATL, 1 or 2 pumps located in an intank collector, less plumbing on both the feed and return...I made one for the new fuel cell I put in my car, we have to segregate the pumps from the cabin, so it saved making a box for the pumps, I made the collector the diameter and depth of the tank with one way valves and the return plumbed back in the collector..
The ATL Setup
My fuel cell with one pump mounted in the plate...
Old 03-02-2012 | 09:18 AM
Turbosimpsons
This is while, imo, its always good to ask, as there is stuff out there, that not everybody knows about.
Old 03-02-2012 | 07:12 PM
stevieturbo
C**t
The ATL Setup
Any more pics or details of the ATL setup ? Cant make any sense of what that's supposed to do ? There are no trap doors for fuel to get into that chamber ? Or is that just one part of something else ?
A well designed tank with internal sump/collector and the pumps mounted as you have is by far the best way to do it. Certainly the neatest. I assume the pump pickup is extended low in the tank ? What have you used as a seal around the pump ?
Old 03-02-2012 | 07:49 PM
J1mbo's Avatar
J1mbo
B1mbo
A single gravity fed 044 will not supply enough fuel for a genuine 600bhp on the dyno, proven many a time on the dyno.
Twin standard pumps would be more than enough but due to the standard push fitting being hard to come by we tend to use 2x 044 with a lift pump in tank or in standard 2wd cradle, escos 023 or a standard pump 2wd
It's a little overkill as that will supply more than enough fuel for 800bhp lol, but they're a good reliable pump you won't have any issues with what your going with it's what I'll be using on my car
Old 03-02-2012 | 09:19 PM
ajamesc's Avatar
ajamesc
how do you account for ad youngs car then?
Old 03-02-2012 | 09:31 PM
J1mbo's Avatar
J1mbo
B1mbo
Not sure but could prove it tomorrow in front of you if you wanted. ask martin hadland what happened with his afr's on his own engine with 1 gravity fed 044 on a -6 line
Old 03-02-2012 | 09:34 PM
ajamesc's Avatar
ajamesc
No need his made 677.4 on a dyno lol i very much doubt there making it up
Old 03-02-2012 | 09:39 PM
J1mbo's Avatar
J1mbo
B1mbo
On a single 044 wow! We're doi something very wrong
Old 03-02-2012 | 09:41 PM
ajamesc's Avatar
ajamesc
No idea your the tunner but the car has one 044
Old 03-02-2012 | 09:42 PM
J1mbo's Avatar
J1mbo
B1mbo
Pressurised through a swirl pot you can see a fair bit more, I don't beleive near 700bhp even pressurised so how that's being done I've no idea
Old 03-02-2012 | 09:45 PM
Turbosimpsons
I'd rather have too much fuel, than not enough
Old 03-02-2012 | 10:41 PM
stevieturbo
C**t
Too much fuel when designed badly will also give problems.
Old 03-02-2012 | 10:47 PM
ian sibbert
Very quick sketch of how I made mine, the ATL system is lovely but very expensive...the whole system is housed in the standard bag tank plate...
I made a cylindrical collector, same depth as the tank, fitted two non return valves in the bottom (to allow fuel in and attached the return from the rail back via a flexible into the collector internally...we only need a single pump on the car, the pump is sandwiched at the swage with an 'O' ring to seal it and a pickup attached to the inlet to the bottom of the tank/collector. I then bolted it all together underneath the plate to fix and bolted it all in the top of the bag tank as normal...
Quick but rubbish sketch...the middle bit is my poor attempt at a pump...lol
The product in demon thieves might explain it better...
http://www.demon-tweeks.co.uk/motors...tchtank-system
Old 03-02-2012 | 11:46 PM
stevieturbo
C**t
So the ATL piece is actually an external item. Not something to go in tank ?
Wondered how the hell fuel from the tank would ever get into it with no openings if it was an in-tank piece !
The problem some run into by returning fuel directly into such a small collector, and one that seems to have little access to the main tank's fuel, is they just create a heating loop for the fuel. Unless it's absolutely essential, I wouldnt be returning all of the hot fuel from the engine bay back into the collector.
Most proper internal collectors have a trapdoor style arrangement on all of the sides to allow fuel in, but not out. These openings are usually quire large too, so the normal motion of the car will ensure fuel is always forced into the collector.
Old 06-02-2012 | 09:15 PM
cossytel's Avatar
cossytel
If you need a twin pump kit i have a brand new ATL going cheap
cossytel's Avatar
cossytel
And a swirl pot
Rob Wells
Ford Mondeo Including ST
18-04-2023 01:19 AM
JK12
33
26-04-2021 01:09 PM
28
08-09-2015 08:10 PM
kevin36
08-09-2015 01:23 PM
ST-170
04-09-2015 12:02 PM
Quick Reply: what fuel system for 600+ bhp
