efi cvh turbo 200bhp target what do i need ?
Old 30-01-2012 | 09:47 PM
Dan j's Avatar
Dan j
Van modder
Default efi cvh turbo 200bhp target what do i need ?
I'm getting a fiesta cvh efi turbo engine in a few months, it has
T3 erst turbo and manifold, and a 165 chip and a air filter, it also ran a pace intercooler. I haven't decided what the engine is going in yet but I'm after a genuine 200bhp from it. The management is ofac so I'm told but other than that ill be doing more research on it all. So guys a list of what I should be getting to hit that target, ill be buying bits when possible.
Old 31-01-2012 | 08:33 AM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
195 chip, beige injectors, front mount intercooler will get you to 200bhp i think m8 you may need a hybrid turbo as well as they run out of puff at around that
Old 31-01-2012 | 01:05 PM
Dan j's Avatar
Dan j
Van modder
How much
Old 31-01-2012 | 01:25 PM
Ben26's Avatar
Ben26
And 20+ psi of boost as well.
Korda's Avatar
Korda
make sure you give your engine a full health check first or you will be spending out on a rebuild. get some pics
Old 31-01-2012 | 01:44 PM
Dan j's Avatar
Dan j
Van modder
I don't intend to go mad on a unknown engine so it would get a health check before I went and did the mods. No pics as its miles away and you all know what the efi looks like, plus its not going in a fiesta either.
Old 31-01-2012 | 05:26 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah a stage 2 T3 (.36/50) will be needed, FMIC, bigger injectors (to be safe as they will be on the limit), suitable chip/remap and doesnt OFAC only have a 2 bar MAP sensor meaning a 14.7psi boost limit?
Old 31-01-2012 | 05:33 PM
Ben26's Avatar
Ben26
Yea ive got a t3 42/.48 and made 207bhp at 18 psi
Old 31-01-2012 | 05:40 PM
Ben26's Avatar
Ben26
Sorry .42/48 nearly forgot the old decimal point there
Old 31-01-2012 | 07:19 PM
Eagle's Avatar
Eagle
Super Moderator
and arp big end bolts ..
Old 31-01-2012 | 07:24 PM
Dan j's Avatar
Dan j
Van modder
So with the above parts fitted it should hit 200 bhp ? Is that going to be a high stressed cvh at that output or will it take it in its stride. I don't want it blowing up on me as the engine is going in a standard looking mk6 escort and it will be a daily driver. Thanks for all the info fellas
Old 31-01-2012 | 07:54 PM
Ben26's Avatar
Ben26
Yes very true. ARPs are a must.
Yea u should be around 200 . With a standard H.G you should be ready to rock n roll.
Old 31-01-2012 | 09:54 PM
Rogeyboy's Avatar
Rogeyboy
I don't think 200bhp is overly stressing it if its a good strong engine to start with, just don't go mad hangin the revs and turning the boost up!
The MAP sensor on OFAC is 2.5/3bar iirc, but its the mapping that holds the boost back, you can get the boost limit mapped out or a suitable chip to replace it.
The Powerchip 195 i had in the car, allowed it to peak 16psi and hold 14-15... Went very well 2!
JK12
33
26-04-2021 01:09 PM
bigryrs
07-09-2015 07:45 PM
RSBryden
06-09-2015 09:39 PM
cozzzzy power
04-09-2015 09:14 AM
turbowag
03-09-2015 09:07 AM
Quick Reply: efi cvh turbo 200bhp target what do i need ?
