Best way to max out a T4?
Old 15-01-2012, 07:54 AM
  #41
wattie
wattie's Avatar
Is it quite a mild cam, would it be fine on a stage 3 engine or are you just better leaving the standard cams in under 400 brake?
Old 15-01-2012, 08:04 AM
  #42
Moonstone Steve.
Moonstone Steve.'s Avatar
From what I have heard its very much like a bd14 but you don't need cutouts, what cam do you have now, Steve went to a AB07 from a std cam and the results were good, but then its all in mapping
Steve
  #43
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Originally Posted by BRAMMER
Steve's block is Playing with him, its waiting for the next Kent rolling road run and its gonna shit its self on the rollers in front of everyone lol
Thanks Chris
Im in the AA so alls good
Steve
Old 15-01-2012, 08:05 AM
  #44
Jasu
Jasu's Avatar
Hi.
I have just serviced original RS500 turbo.
Wonder how it fits with the Mountune MT29/MT30 cams (288ş 11.6mm / 282ş 9.6mm)?
Old 15-01-2012, 08:08 AM
  #45
BRAMMER
BRAMMER's Avatar
Sorry mate, Its done well up to now and its not shy'd away from producing good figures, the only downside to it is its actually restricting you from really testing that turbo and all your other bits - I would be tempted to start you 200 build soon
  #46
cossie4i+
TT T38 Power
cossie4i+'s Avatar
AB07 has 8.85mm lift and 256 degrees duration
BD14 has8.91mm lift and 261 degrees duration.
You dont need valve cutouts with the AB07
Standard Cam (BD8) is 8.5mm lift and 241
Steve
Old 15-01-2012, 08:11 AM
  #47
Moonstone Steve.
As your now sitting at your computer with a hard on Steve, what is the bd15 lift and duration
Steve
Old 15-01-2012, 08:12 AM
  #48
B13 JUS
B13 JUS's Avatar
Originally Posted by J1mbo
The compressor maps for a t4 and a gt3076 show that the g3076 should make much more power than the t4, it flows something like 6lb of air more on the compressor map.
But, due to the exhaust wheel they will make pretty well identical power to a t4 at the same boost, maybe 5-10 bhp more.
The exhaust wheel of a t4 is big, hence being slightly more laggy, where a gt30 has too small a ex wheel for the compressor wheel but gives good response.
Mat, I've no idea why any body would want to run that boost on a t4, rediculous IMO
Gareth, I wouldn't advise that comp ratio but have driven one at 7.2 and the word for it is raw, very un progressive, awesome feeling but in the real world not good
Jim you'll be talking about the cr turbos gt30 there.
The gt30 thats on the garrett website is what Brammer has and I had.
It's smaller than cr turbos version with a 6 blade turbine wheel not 7.
I remember you dad saying that turbo (smaller version) spooled up quicker but the cr turbo version made more bhp.
Old 15-01-2012, 08:14 AM
  #49
bigchez
bigchez's Avatar
Looks great Luke, altho the interior was almost too good to strip - have you kept it? Have to say I prefer the weels you have on it too. Should be well north of 500 hp by the time you've finished matey, good work but I bet your wallet has been significantly lightened now!
Been saying it the last couple of years, but hopefully catch you at a show this year chap.
Old 15-01-2012, 08:20 AM
  #50
bigluke200
bigluke200's Avatar
Lol! In spectacular fashion I can see the headlines now:
"10 killed by giant man's exploding fake car"
Old 15-01-2012, 08:28 AM
  #51
bigluke200
bigluke200's Avatar
Thanks mate, yep my wallet is significantly lighter but enjoy spending money on her
I didn't keep the interior as it took up too much space it's only resale value that will be affected and I'm not gong to sell up any time soon it is fookin noisy though
Yes mate, I've still got your number so would be great to catch up and have a good old chinwag.. Will prObably be at central day although carless!
Old 15-01-2012, 08:32 AM
  #52
bigluke200
bigluke200's Avatar
Originally Posted by wattie
Who makes that ab07 inlet cam, that's the one that works fine with standard pistons?
I have one available dyno miles only!
Was well impressed with it tbh 471bhp/400lbs on half a map!
  #53
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Steve
Back now, just had breakfast lol
BD15 is 10.03mm lift and 258 duration
Steve
Old 15-01-2012, 08:35 AM
  #54
cossie4i+
TT T38 Power
cossie4i+'s Avatar
It looks like we are taking bets on my car exploding at the Kent RR Day
Steve
Old 15-01-2012, 08:50 AM
  #55
bigluke200
bigluke200's Avatar
It'll be fine mate anyrhing new on it since the last rr run?
Old 15-01-2012, 09:17 AM
  #56
BRAMMER
BRAMMER's Avatar
Thats it Justin, i have a 4inch anti surge, 6 fin compressor wheel with the .60 A/R housing - seems to be lot's of info on the net around the skyline forums regarding the difference between the 6 and 7 blade but it completely baffles the shite out of me - apparently the 6 is the newer version and better - loads of talk about GT3037 which i think is HKS spec (not 100% on that but..)
Old 15-01-2012, 09:19 AM
  #57
cossie4i+
TT T38 Power
cossie4i+'s Avatar
The Hart inlet, intercooler moded with a 70mm outlet to match the TB and air injectors.
Still needs to go for mapping
Steve
Old 15-01-2012, 09:22 AM
  #58
B13 JUS
B13 JUS's Avatar
my mate has been in my car who has the cr turbos gt3076 and said he thought mine spooled up quicker than his.
cr turbo's use the 7 blade with a .70 A/R compressor which is the same as a gt35. this has a 4" intake but not anti surge like ours.
Old 15-01-2012, 10:02 AM
  #59
BRAMMER
BRAMMER's Avatar
From how it reads on the skyline forum the 7 blade version with the .70 A/R is not ideal - so are you keeping the GT on for now until the BW is available
Old 15-01-2012, 11:10 AM
  #60
B13 JUS
B13 JUS's Avatar
no mate, its already sold and replaced with a bw300sx, twin scroll manifold and a straight through 4" exhaust system.
i'll see what this turbo is like but if i want the new efr turbo everything is already done. i will only need my exhaust modding.
Old 15-01-2012, 11:15 AM
  #61
J1mbo
B1mbo
J1mbo's Avatar
That's not a fair comparison as two engines can differ massively, the only fair way is to try both turbos on the same engine and see the difference
I don't think we have used a 6 blade, but I don't think the 7 blade is a gt35 wheel they're much bigger
Old 15-01-2012, 11:40 AM
  #62
wilky
wilky's Avatar
a t4 to try out wet bearing ,may work may not
Old 15-01-2012, 11:50 AM
  #63
mechanic28
mechanic28's Avatar
my t4 is maxed out only hit 28psi on the rollers and made .................................................. .................................................. ...........
wait for it
416.1 bhp thats with touring car spec head 7.2.1 c/r and 16/14 cams
Old 15-01-2012, 12:00 PM
  #64
cossie4i+
TT T38 Power
cossie4i+'s Avatar
wait for it
Poor old thing, thrashed by a old XR4i
Steve
Old 15-01-2012, 12:07 PM
  #65
mechanic28
mechanic28's Avatar
Steve
go away i think it might need tony magic lol
Old 15-01-2012, 12:17 PM
  #66
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
wait for it
28psi a turbo is an air pump why not let it pump some air lol put some boost into it people run almost that in a t34 with 350
Old 15-01-2012, 12:22 PM
  #67
bigluke200
bigluke200's Avatar
wait for it
Sorry to hear that mate, what do you suspect that the problem is?
Old 15-01-2012, 12:23 PM
  #68
mechanic28
mechanic28's Avatar
ah true but 28psi on a t4 for a t34 to pump the same volume of air would prob need to run at 40 plus psi all the time
Old 15-01-2012, 12:43 PM
  #69
J1mbo
B1mbo
J1mbo's Avatar
Your missing the point, at that boost it should be making a minimum of 460bhp I'd expect my own engine to be making 480/90 at that boost
Old 15-01-2012, 12:54 PM
  #70
BRAMMER
BRAMMER's Avatar
wait for it
Who's rollers was that on? and has it been sorted or found out why it only map that much?
Old 15-01-2012, 01:15 PM
  #71
ajamesc
ajamesc's Avatar
i wasent making any points i was just asking why run such low boost
Old 15-01-2012, 01:26 PM
  #72
Karl 3dr
Karl 3dr's Avatar
Originally Posted by sapph1
Mine is running a t4, 15 inlet, 14 exhaust, 7.2cr, 8 greens etc, bearing in mind that it is purely a road car, would I benefit from changing to a 16 inlet or would it be a backwards step as far as response goes? Also, what gains in bhp/torque would I expect to see?
Karl
Has anyone got any ideas on this please? Jimbo maybe?
Cheers, Karl
Old 15-01-2012, 01:27 PM
  #73
R5FORD
R5FORD's Avatar
my SCS built 500 engine with a T4 made 545hp with 31psi so 28psi is not really low boost in comparison
Old 15-01-2012, 02:06 PM
  #74
B13 JUS
B13 JUS's Avatar
I didn't say the 7 blade was a gt35
It's the .70 A/R housing is the same as the gt35
Old 15-01-2012, 02:17 PM
  #75
J1mbo
B1mbo
J1mbo's Avatar
Sorry mate was skim reading whilst playing cod
Old 15-01-2012, 08:04 PM
  #76
cossie4i+
TT T38 Power
cossie4i+'s Avatar
You know the man can
Steve
Old 15-01-2012, 08:13 PM
  #77
GARETH T
GARETH T's Avatar
wait for it
are you cams dialed in,, and get it remapped
Old 15-01-2012, 08:15 PM
  #78
cossie4i+
TT T38 Power
cossie4i+'s Avatar
It was the first time Doug had used the car after being set up by MSD
Steve
Old 15-01-2012, 08:30 PM
  #79
James @ M Developments.
James @ M Developments.'s Avatar
Yes Steve correct a set up.
That doesn't include dialling cams in.
We checked the base calibrations and ensured the car was safe for hard use, which it was,
When the car was mapped some years ago it was peaking at 2.2 bar holding 2 bar to the limiter,
Carry on trying to stir shit all you like pal, I expect nothing more from you these days tbh!
If Doug wants us to up the boost and find every ounce of power he has available all he needs to fo is ask and we will do so.
If you study the rolling road day you will see some of our off the shelf calibrations did quite well, and looking at the maps side by side dougs has more ign and more fuel but makes less power lol that's dyno bollocks for you
Old 15-01-2012, 08:33 PM
  #80
GARETH T
GARETH T's Avatar
if those are the facts,, and he hasnt got any other issues (like his front pulley key has warn) than its either cam timing,, or dyno shit
Quick Reply: Best way to max out a T4?
