Stainless steel welding
Im looking to fabricate my own exhaust in stainless steel for my mk1 project, what im wondering is can i tack weld the bits together with my mig? I would then get the local welding company to tig it all up.
Cheers,auld
Cheers,auld
you could just tack it with your mig , the welder will then re tack it inbetween your tacks with his tig then grind off the old mild steel ones and weld it up.
You could do the entire thing with the MIG.
Why are people obsessed with TIG ?
For an exhaust, TIG is pretty and nothing more.
If you want it to look all nice and pretty, by getting it professionally TIG'd together. There is no point tacking it with mild steel wire with your MIG. Unless they intend to grind the mild steel back out again.
You'll need to buy a roll of stainless MIG wire. But if you can weld, may as well just MIG the entire thing that way.
Only if you're really really shit at welding.
Even I'm beyond that stage and can weld pipes together with little or no protrusion with a MIG.
The only time there may be a little is if trying to fill gaps. So just cut the pipes so there are no gaps, then everything is neat inside.
Testing the future
why does it take 2 people to tell you something you already know before you belive it? if the wire is made of mild steel that rusts, how could it possibly suddenly not rust, just because you've plonked it on top of stainless?
for anyone who wants to know a little more about welding, have a watch of this guys videos on youtube
http://www.youtube.com/user/weldingt...eature=g-all-u
get it tig welded,much better weld if done properly with argon backing gas aswell,or purged as its called,that will give the weld full penatration,any welder worth his trade will know what to do for a good weld,even more so on a exhaust,with all the heat exchange,mig tack it up,then get it tig welded properly after imo,job done
Why's that ? You wont do much body repairs with TIG. You wont make quick brackets, tack stuff in place one handed with a TIG.
As already stated. TIG is great if you need it to look pretty. Other than that there is pretty much no benefit, especially for an exhaust.
It's a bit like the yanks obsession with TIG'ing rollcages. Most of them will say if it isnt TIG welded, it's useless or weak.
I guess WRC dont build theirs right.
So in your eyes. What are all the benefits TIG offers that make it so superior ?
Boosted 122 cu in
To be fair we are talking about exhausts and fabrication.
Aluminium brackets, get the TIG,
How many rally cars barrell roll at 330mph or even 200mph? I've worked on pro mod cars and I think having a TIG welded roll cage has saved people.
TIG is stronger and far easyer to control heat and penetration.
I still use the mig for fitting panels and hate being burnt ha ha.
Thanks for all the replys guys!
Think i mite get some stainless wire and get it all tac'd up then get a local welder to tig it all together.
Any recomendations for a small 5kg roll?
cheers,auld
cheers,auld
How many drag cars impact directly into trees at any speed ? Or how many might fall off a cliff and drop hundreds of feet ? None that I can ever recall.
Drag strips are designed so there is little chance of any direct impacts which would cause severe damage.
A proper weld is a proper weld regardless of method.
And what you you mean by recommendations for a 5kg roll ? Any welding supply shop should have it. 5kg will last you a long time, and stainless isnt overly cheap.
Although it can do no harm having it.
i have a GRS motor sport Radiator that has small leaks either side at the top of the radiator, i was told it can be repaired but its made of ally so its a bit of a job.
can anyone on here do the job to fix it ? will pay !!
all hoses and header tank itself is all tight and top notch, its the radiator itself as you can see the pink coolant stains from where it was leaking.
I can weld alloy but your a bit far away really,but if you are desperate i live near wokingham berkshire.pm me.I have the right alloy grade rods for rads.
i made my own exhaust using the mig stainless wire and argoshield light,unless you use pure argon it will be slightly black but works perfectly well.turn the amps and wire feed up and pulse weld it.it will spatter unless you use anti spatter spray.if you going for a shiney magazine look exhaust then its worth using some.
if you look down the the exhaust you can see there is good penetration but also not alot of weld on the inside,not bad considering I didn't purge weld it.
You're weld is quite obvious in the photo ( not making a dig BTW as it's probably neater than a lot of mine lol ), but the weld to the right is also MIG'd
I have done similar welds myself. Although I wouldnt be able to manage a full circle around a pipe. If both pieces are clean and the settings are right, and no air gaps to fill, then it is very achievable. Maybe not as perfect, but very close.
tig is all well and good,, and i personally love tig,,, but it has one massive disadvantage, its slow!
if you gotta pay for someone to do the welding,, there is nothing at all wrong with mig!
yeah should of pointed out the weld on the right was done on a welding lathe and yes it was mig.I had to use 0.8 wire as thats the only stainless wire i had.It would of been better with 0.6 and amps and feed turned down.With pipes its sometimes easier to trigger pulse weld like i did as you get a uniform looking weld rather than overlaps from continious welding and stopping to rotate the work.I was more concerned about too much weld protruding on the inside of the exhaust.
the guy from grs only works after hours from his normal job so not a big company but he does turn out some good stuff.all custom hence the price tag.
