Square Beams
Old Feb 22, 2005 | 02:10 PM
ian sibbert's Avatar
ian sibbert
Default Square Beams
I have an oppotunity to produce some new square beams...would anybody be interested in them?
They would work out about £400.00 i'll try and post a piccy of the item we have to copy off...these will be pukka items...made from decent material...
Best regards
Ian
Old Feb 22, 2005 | 02:19 PM
Ryan's Avatar
Ryan
what about arms?
Old Feb 22, 2005 | 02:43 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yeah, what arms would they be using and are they adjustable?
what's the advantage of a square beam?
Old Feb 22, 2005 | 02:45 PM
Ryan's Avatar
Ryan
square beams are generally used with mag arms.
Old Feb 22, 2005 | 02:59 PM
ian sibbert
i may be wrong....i'm sure i'll be corrected but i thought you could run the square beam with modified steel arms....rose jointed on the outer link for track...inner for the camber adjustment....it's a long time since I set a car up with either this or the mag arm setup but i'm sure its possible....the square beam and mag/steel arm setup helps reduce bumpsteer....
Old Feb 22, 2005 | 03:15 PM
Ryan's Avatar
Ryan
yeah they can be run on modded steel arms, but not standard items. Hence why it would be more helpful if it had arms aswell.
What are you hoping to achieve by running a square beam?
Just out of interest? over a round type beam.
Old Feb 22, 2005 | 03:24 PM
Tony Ryan's Avatar
Tony Ryan
In my limited experience , and i only tried this once ! The square GpA Tarmac beam ( red ) and steel modded rear arms mean problems with driveshafts, no-one i know runs this configuration , although loads of people use a std round rear beam and mag rear arms , though you should be aware of this ! Also square beams bolt up in a completely different way , the eye bushes are designed to be solid and there is no top mount on the diffs , this means GpN or GpA diff mounts are essential .
My tuppence worth anyway !
cheers
Old Feb 22, 2005 | 03:25 PM
ian sibbert
I don't run a square beam I run a cradle and lateral links....as the post says I have a customer who wants a square beam off me...which I have....I have a fabrication shop in which I was going to reproduce 10 square beams to sell if there was enough interest...hence the post...I havn't got any arms...mag arms as you know are getting thin on the ground...the square beam mounting points are different from the tubular version..this mod to the mounting points improves bumpsteer...not an issue if you are on a nice flat track so i take your point about what I am trying to acheive...nothing...I don't have the of masive bumpsteer...i was merely trying to gauge if it would be a worthwhile exercise producing 10..or not and having it tied up in my workshop....
Regards
Ian
Old Feb 22, 2005 | 03:37 PM
ian sibbert
Fair point tony that's the answer I was after....is there a demand....no....there is an issue with the driveshaft no....we run equal lengths on both sides of our car with a 20mm spacer on the o/s....there are several levels of beam blue, red and i think black....I realise the square beam bolts up differently...i have never come across a grp'n' diff mount....that would be a standardish item...the grp'a' rear diff mount uses the bush arrangement similar to the proper gearbox mount or a solid back plate mounted through bosses onto the diff plate attached to the cage....ive built quite a few grp'n' and grp'a' cars...and wrc escorts.....
I will sell the beam I have....
Best regards
Ian
Old Feb 22, 2005 | 03:42 PM
Ryan's Avatar
Ryan
i have a grp N diff mount. Kindly spotted out by tony one day, looks almost identical to a standard item but has alot more rubber surrounding it and less hoses.
Part number is: 9094679
Have you got any pictures of your reat set-up sib?
As im currently in limbo as to what to do with the rear of mine.
Old Feb 22, 2005 | 03:52 PM
ian sibbert
I'm not going to argue about grp'n' items....it's a whole subject itself.....we have the wrc setup on the rear of our car....but even this had to be tweeked to acheive 0 bumpsteer....if i was building a race car as you..i'd try and ditch the tube beam....go square and a pair of mag arms....the main reason for building the wrc car was to save all the weight in the back end and improve the car over the fast bumpy stuff...
Regards
Ian
Old Feb 22, 2005 | 10:49 PM
CozzyBrom's Avatar
CozzyBrom
sounds a rip off to me
zoo do a full beam including arms rose jointed beam bushes modded pick up points for £550 for the road beam complete
i it uses standard drive shafts so i dotn no where u got it runs problems using a modded steel one
Old Feb 22, 2005 | 10:54 PM
ian sibbert
Total rip mate..no need to worry..the beam I had went on its merry way to ireland...wish i'd never even started this little topic.....
ian sibbert
Regards
Ian
Old Feb 22, 2005 | 11:14 PM
ian sibbert
I never actually said it would be a problem running a conventional beam with modified pick-up points...the point of the exercise was to gauge demand.....the majority seem to favour a modified convential beam....i was suggesting offering a copy of the genuine ford motorsport part...there s no deman...to suggest its a rip off is a little harsh...all items we produce for competion cars are meticulously engineered and the beams would have been laser cut and tig welded together as the originals were....I am in an engineering environment professionally and to carry out construction of the beam alone would require at least 1 man day....
As I said eailier...no demand...no problem...
Kind regards
Ian
Old Feb 22, 2005 | 11:17 PM
Ryan's Avatar
Ryan
Sib, think you being a little touchy mate.
Can you not do arms to suit the beam?
Old Feb 22, 2005 | 11:21 PM
ian sibbert
I'm only playing mate....ive dealt with several people on this forum...nothing I produce is a rip....i actually like the debate on here...it gets the old juices flowing...no mate i cant help with arms...i do have a pair of green mags with hubs etc but they are serious money...
Best regards
Ian
Old Feb 22, 2005 | 11:23 PM
RichardPON's Avatar
RichardPON
Ian,
Remember, there's only a select few on here who even know what square beams are.............. so I don't think the demand will be huge.
By the way, any chance of some pics of your car?
Old Feb 22, 2005 | 11:25 PM
Ryan's Avatar
Ryan
how much we talking on the arms?
As i've been offered a complete square beam and mag arm\hub setup.
But unsure whether to commit to it yet
Old Feb 22, 2005 | 11:57 PM
CozzyBrom's Avatar
CozzyBrom
not havig a dig iether just a bit of box sectoin and lazer cutting is alot for a beam when you got to find arms aswell
Old Feb 22, 2005 | 11:59 PM
Ryan's Avatar
Ryan
"bit of box section"
Old Feb 23, 2005 | 06:45 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
i am using a square beam on my new car together with fabricated multi tubular rear arms and am looking for someone to reproduce this, are you the man ian?
Old Feb 23, 2005 | 07:39 AM
ian sibbert
Sure can Martin...i'm a little reluctant to only do one but i'll post you a pic of the ones' I have at the mo...we have a jig already set-up i'd prefer you to just check dimensions before we go ahead....
Best regards
Ian
Old Feb 23, 2005 | 08:32 AM
Martin-Hadland
ian, not interested on one... would be into 5 at a time.
Old Feb 23, 2005 | 08:40 AM
Porkie's Avatar
Porkie
Planning on a few more crashes huh mate
Old Feb 23, 2005 | 08:59 AM
B19-TRB's Avatar
B19-TRB
Ah so thats what u were talkin about martin!
Old Feb 23, 2005 | 09:52 AM
Martin-Hadland
nope, but you never know!
Old Feb 23, 2005 | 10:04 AM
foreigneRS's Avatar
foreigneRS
Testing the future
martin, if you're going to all of the trouble to fabricate new beams and arms, why stick with the semi trailing arm principle? why not fabricate a double wishbone arrangement that gives better geometery control?
Old Feb 23, 2005 | 10:26 AM
RichardPON's Avatar
RichardPON
Cooooooooooooooool
Old Feb 23, 2005 | 10:35 AM
DaveEscos's Avatar
DaveEscos
Ian, you say you build wrc and grp A cars
can you source front wrc bumpers and rear spoilers for the wrc escort?
and steel front wings?
cheers
Dave
Old Feb 23, 2005 | 11:02 AM
Spiky's Avatar
Spiky
cheers
Dave
go see your post in the wanted section
Old Feb 23, 2005 | 10:12 PM
ian sibbert
cheers
Dave
You have p.m. dave
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
3doorcozmess
Sep 7, 2015 01:32 PM
cameron2
Sep 6, 2015 10:40 AM
