how well would this work
Old Feb 22, 2005 | 10:58 AM
jonesymk2's Avatar
jonesymk2
Default how well would this work
how well would a t28 turbo from an escort cossie work
on a s2 erst
Old Feb 22, 2005 | 12:41 PM
Holty's Avatar
Holty
Queue Davie K....
Old Feb 22, 2005 | 04:48 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Default Re: how well would this work
on a s2 erst
very well with the right specced engine
wheres davie when you need him
Old Feb 23, 2005 | 07:58 AM
jonesymk2's Avatar
jonesymk2
just that theres one on ebay at the moment,what spec would it
work best with then
Old Feb 23, 2005 | 08:13 AM
T28 RST's Avatar
T28 RST
Ok then
Ive had a T28 on my RST for over 2 years now, it is a great conversion, a bit expensive but worth the money.
Old Feb 23, 2005 | 08:21 AM
jonesymk2's Avatar
jonesymk2
what else is needed for this conversion then,theres a t28 on ebay
at the moment and i get paid at the weekend so hav been considering
bidding on it but dont want to go ahead with it if its going to be a
massive job to do cause i hav to use my car every day
Old Feb 23, 2005 | 08:25 AM
T28 RST's Avatar
T28 RST
Ok then
AVA did the conversion for me but they changed my downpipe and the water hose is a different shape apart from that its a pretty straight forward conversion.
Old Feb 23, 2005 | 08:37 AM
jonesymk2's Avatar
jonesymk2
not to bad then really,hardest bit would be finding a piece of downpipe
to use and join to my existing exhaust,at the moment my car has got
air filter,ashley exhaust,unknown chip,bigger saab intercooler and
i think it has a power engineering head but not sure on this part,im
hoping to get a 1.8 zetec bottom end soon maybe so would the t28
work well with any of these bits
Old Feb 23, 2005 | 08:39 AM
jonesymk2's Avatar
jonesymk2
hav you got any pics u could send me atall
Old Feb 23, 2005 | 08:42 AM
T28 RST's Avatar
T28 RST
Ok then
This is the spec of mine:
1618cc CVH, stage 2 head , newman cam, solid lifters, piper vernier, wire ringed block, lowered compression, ARP conrod Bolts, AVA ecu, AVA modified fuel system, AVA high flow tubular manifold, T28 turbo, 360 bearing, reshaped front pipe, AVA Large capacity intercooler, magnecor leads, magnex exhaust, AP 4 paddle clutch.
It will work fine on your engine
Old Feb 23, 2005 | 08:43 AM
T28 RST's Avatar
T28 RST
Ok then
I will take some pics when it stops snowing.
Old Feb 23, 2005 | 08:51 AM
jonesymk2's Avatar
jonesymk2
ok cheers for that cheers for the help,i will put a bid in on
the turbo at the weekend then to see if it goes up any before that
its only at Ł200 at the moment,the picture of the turbo on the housing
that goes to the intercooler theres sumthing that looks like a valve
hav u any idea what this is for
Old Feb 23, 2005 | 08:53 AM
T28 RST's Avatar
T28 RST
Ok then
Sorry havnt got a clue
Old Feb 23, 2005 | 08:58 AM
jonesymk2's Avatar
jonesymk2
ok never mind,cheers for the help thuogh
Old Feb 23, 2005 | 09:04 AM
jonesymk2's Avatar
jonesymk2
hopefully then if i can get the turbo and the 1800 zetec bottom
and get it all built up i will hopefully hav my 2 door estate by then
and the engine will go straight into that then
Old Feb 23, 2005 | 09:13 AM
Westy's Avatar
Westy
jonesy..
Whats the Ashley zorst sound like on your RST?? my mate had one on his car, and it was the loudest exhaust I have ever heard
p.s. Luton...
Old Feb 23, 2005 | 09:23 AM
220TC's Avatar
220TC
standard re-circ dump valve maybee
Old Feb 23, 2005 | 09:27 AM
T28 RST's Avatar
T28 RST
Ok then
jonesymk2's Avatar
jonesymk2
its the loudest ive heard aswell went to santa pod the other week
and my mates said it was the loudest erst there,i raced my mate in his
200sx and hes got a sports exhaust on that and he could hear my car
over his and thats when we were doing the runs up the strip so yeh it
is loud but i like it only a 3 inch tailpipe and its louder than all
the rsts ive seen with same size and bigger tailpipes even on tickover
Old Feb 23, 2005 | 09:29 AM
jonesymk2's Avatar
jonesymk2
thats the one t28 rst,says its brand new,thats the valve i was on about aswell
Old Feb 23, 2005 | 09:49 AM
220TC's Avatar
220TC
yep, thats a standard re circ dump valve, the T25's have them aswell I think, like on the rover turbos.
Old Feb 23, 2005 | 09:53 AM
jonesymk2's Avatar
jonesymk2
would i hav to just blank that off then or run the pipe to the inlet
manifold
Old Feb 23, 2005 | 10:00 AM
220TC's Avatar
220TC
Im not quite sure whether it would work if you connected it up, cant think of any reasons why it wouldnt
You can blank it off, either buy a spacer to replace the spring in there or get a plate made up and take it totally off, its up to you. If you have a dump valve installed elsewhere in the system then you will deffinately need to blank it off.
Duncan
Old Feb 23, 2005 | 10:01 AM
T28 RST's Avatar
T28 RST
Ok then
Mine is just blanked off
Old Feb 23, 2005 | 10:06 AM
Westy's Avatar
Westy
jonesy
What times did you get at the pod mate?? bearing in ine the track must be slippy
Have i seen your car about?? What colour mate?
Old Feb 23, 2005 | 10:11 AM
T28 RST's Avatar
T28 RST
Ok then
Does anyone else have this conversion on there car
Old Feb 23, 2005 | 10:19 AM
jonesymk2's Avatar
jonesymk2
ive got a dump valve on my car at the moment but when i get my
estate the dump valve will be coming off so i will just blank it off
on the turbo,westy my best time at the pod was a 15.966 but the
front wheels were spinning in 1st and 2nd also with 17inch wheels
so next time i go im trying 15s and yeh it was slippy,my erst is
black aswell,e plate sitting on 17 inch 6 spokes
Old Feb 23, 2005 | 10:21 AM
T28 RST's Avatar
T28 RST
Ok then
jonesymk2 you have PM
Westy's Avatar
Westy
good effort
when i get my
Estate, whats all that about??
Old Feb 23, 2005 | 10:33 AM
jonesymk2's Avatar
jonesymk2
cheers t28 rst,got ure pics better than nothing cheers
westy im buying a mk4 escort 2 door estate,my car lets water
in around the fuse box so when i wash it or it rains heavy i get
a puddle in the drivers footwell,all the bulk head round the fuse
box has been repaired b4 and its been bodged so im getting the
estate from 1 of my cousins mates for Ł100 and im going to swap
everything over from mine into the estate and make it a bit of a
street sleeper
Old Feb 23, 2005 | 02:51 PM
jonesymk2's Avatar
jonesymk2
will the t28 turbo bolt onto the standard erst exhaust or would i
hav to go for an aftermarket item
Old Feb 23, 2005 | 04:29 PM
T28 RST's Avatar
T28 RST
Ok then
Think it will bolt onto the std manifold
Old Feb 23, 2005 | 05:38 PM
big_wig_074's Avatar
big_wig_074
200 pounds?????????????? i just bought a minty 30k mile old one with uprated actuator for 67 quid on ebay! STOP BIDDING NOW YOU CAN GET CHEAPER!!!!!! and mines goin on a 1.8 zvh too,copy cat!
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
