2.0 pinto
Any of you guys preferably close to me know of anyone with any 2.0 pinto/cosworth blocks only that I could lend just to mock some engine mounts up for my sunbeam conversion. Just to save me lifting the full cossy lump in and out and getting it positioned right would be even better if it had a 2wd sump on but not essential as I'll get one. Did have a spare but can't find it. Thanks, Darren.
I've actually bought cosworth chassis mount kit in off a company on eBay but it comes in bits iam just needing to sit a block/sump in place bolt the square plates onto the engine work out where the other bits will sit on the chassis cut out the lip so they sit rite on the chassis possibly tack it in place and then work out the angle and length from the bit tacked to the chassis to the actual square plate bolted to the block (if that makes sense lol) and cut and weld the connecting tube to make the completed mount up
I've picked up a 1600 block off a guy I know. I presume the blocks the same as the 2000 and I'll be able to make my mounts up from this? Iam just needing to find a 2wd sump now. I did have one but can't for the life of me find it.
mk3ste
17-10-2021 10:09 AM
chowfornow
14
05-01-2019 09:01 PM
