Intercooler, whats best? Bar and plate or tube and fin?
As titled. I'm building a high power engine inc the use of a GT35 pushing up to 2 bar. What intercooler type would suit best, bar and plate or tube and fin?
Any ideas would be of help
Happily retired
Wrong question ask about flow & hence less loss of horsepower.
Mine shows +7 on ambient coping with 840bhp on a GT42 @ 2.8bar. The bigger is better nonsense dont apply to intercoolers its efficiency that counts. Most fit an intercooler the size of a super nova & then can only get 50% airflow to it. Design your intercooler so that it can get as near as possible to 100% airflow so smaller & a lot thicker helps. Have your inlet pipes so that it uses 100% of the area of cooling not as we see on the majority entering in the side or back.
This cooler
mounted like this gives the best results ive come across.
This cooler
Cheers Rod. I have an airtec front mount on my Foc RS at the moment, I was wondering if it was man enough for the job. I read alot about people increasing the pipework diameters to increase the flow and cfm's. I was considering changing the end caps to suit 3" pipework purely because I have a 3" t/body. Whats your thoughts? I know you know youre onions
Ive just had a good look at my cooler and I reckon that changing the inlet and outlet to 3" then fitting scoops on it to channel the air would be my best option. Most of the performance coolers are using some sort of air guiding fins around them.
TT T38 Power
Not yet refitted and tested yet.
Steve
Thanks again Steve. It's all starting to make sense now. Increase flow and efficiency and reduce restrictions including changes of diameter in pipework to reduce friction and turbulence
Yeah Ive just checked that. I reckon I'm going to stick with the Airtec cooler and just increase the Id of the pipework to 76mm. That combined with some fins to channel the air through the core should give me a good result. If not I'll have to sit down with the spec r boys
Bloody hell that takes me back to my engineering days. Interesting read though, cheers for the link
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
155lee
24-10-2015 11:11 AM
