eec4 throttle body to hart plenum cable bracket
Old Dec 31, 2011 | 04:10 PM
Turbosimpsons's Avatar
Turbosimpsons
Default eec4 throttle body to hart plenum cable bracket
today i have modded my ecc4 throttle body and made a bracket for my hart plenum. as no one seemed to supply one i made my own.
hope you like it
Old Dec 31, 2011 | 09:13 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I will see how well my one from Joe Stephens works
Steve
Old Dec 31, 2011 | 09:25 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i have the same as above! but havent fitted it yet but the car is at work in the workshop so hopefully it will be a bit quiet next week and ill get a chance
Old Dec 31, 2011 | 09:27 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Tell me how you sort your PAS lol
Steve
Old Dec 31, 2011 | 09:36 PM
ajamesc's Avatar
ajamesc
I was told ill have to shorten/mod the pig tail pipe and thats it but i havent even looked yet to be honest! But if i do run into any probs ill do as my mate has done on his saff with a hart plenum which was to remove the pump and ford power stearing set up and go electric with a merc a class pump and modded standard hoses/pipes to the rack which were sorted by a local hydraulics company
Old Dec 31, 2011 | 10:13 PM
BRAMMER's Avatar
BRAMMER
Steve the end of the the bracket you have is what i ideally need, i have a Spec R bracket and the cable doesn't lock into the bracket like it does on the standard YB bracket.
2wd pump mod is easy to drill and tap for a M18 banjo bolt or go for one of Auto Specialists conversions which is Ł30
Old Jan 1, 2012 | 08:24 AM
Turbosimpsons
The bracket that is supplied as part of the fitting kit (from the guy that makes them) uses two of the three bolt holes in the plenum and reverses the way the throttle body mechanism works (so the cable pulls the other way) wich imo. Looks more factory.
Old Jan 1, 2012 | 08:29 AM
Turbosimpsons
Steve
how much was your bracket? Steve.
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
muz
Sep 30, 2015 08:29 AM
