evo engine fitted the same way as a cossie engine
does anyone no of a car that has an evo engine fitted this way, thinking of rear wheel driving this engine what box to use and any pics on the net cheers. rich
just been on there website, pretty wild gearbox not for me though, for a road car something along the lines of skyline gts box. flywheel clutch bellhousing etc to beconsidered or a tremec.
just been on an american website and they make a bellhousing to fit the 4g63 evo engine on to a t56 which i believe is a 6speed out of a corvette and pretty similar to a t5 borg warner i know the input shaft is bigger and less splines.
http://www.chevroletls1.com/engine_i...earbox_erv.jpg
http://www.britishv8.org/Articles/Im...Number-Tag.jpg
ok thanks for the input, looking to put all this in to a sierra sapphire, what flywheel clutch etc do you use thanks rich
Depending on bellhousing you may have to massage the tunnel with a hammer but the T56 goes in the Sierra shell.
It is bloody heavy though...
http://www.youtube.com/watch?v=lX0MB7pJtKs
The similarities are...
They both have T5 in the name
They both have 5 gears
They are both rwd
They are both made of metal
They both have a gearstick
Of course, the same can be said of any rwd stick in the box gearbox, so they are all similar.
But you'd need to pay close attention to the ratios available if fitting one to a 4cyl engine. The ratios are very tall, and far from ideal for a low powered/torque engine unless you run a very short diff.
Zee Germans are coming
as said norris design's swb evo9 runs the engine in said guise but thats the easy bit
its the rest that costs the money
think he qouted 100+ grand to build that car
But other 4 cyl rwd turbo options.
Nissan 200 ?
Volvo 940 turbo etc
and for some reason, I cant think of many others lol
6cyl does open up more options
Nissan 300
Skyline
Supra
others ?
Sponsor
If you use a evo 7 onwards flywheel you can use a evo cover cossie plate ans the splines are the same
unless you want to keep it under 400bhp then buy a a forged 4g63 as standard engine unless a 8mr or a 9 the rods will pop out to say hello above 400 bhp
edited so the ford boxes should fit with correct bell housing
[QUOTE=Chip;5749783]Lol @ thinking its inferior, far more potential than the YB and cheaper to buy as well.[/QU [IMG]http://i1014.photobucket.com/albums/af262/arslicker/2011-12-10191357.jpg
When you consider the cossie internals will take over 500bhp standard. it wasn't that funny a comment .
[QUOTE=Sanchez_;5750007]
steve from steve hill motorsport told me that cosworth make the evo engine or designed it cant remember witch
we was chatting when i took my 6 for a service and geo set up
*** Sierra RS Custard ***
It was when you think that most of these engines are over 20 years old so if you want to actually run 500bhp on them the first thing you need to do really if you want it even vaguely reliable is to rebore it and buy new pistons for it anyway, at which point the difference in cost between rebuilding it and rebuilding an YB engine is only the price of a set of rods and the evo engine is dearer to begin with, and on the evo engine you dont need aftermarket cams or headwork to see 500bhp.
The only way a YB engine is really significantly better than an evo engine is if you want to stop a boat floating away with the tide.
But obviously in a Cosworth environment, ie a Sierra etc....Making an Evo engine fit would cost a few quid.
I dont think the OP has actually stated if this will even be in a Ford ?
Sponsor
your about the only one that does Rick lol !! i have a 7 engine in mine doing 370bhp 360lb and all i keep being told is im guna break a rod ! its done 70k and when i got it maybe running 330 bhp i remapped it to 1.7 bar and kicked its teeth in ever since and it hasnt looked sideways in 12 months lol
