trigger wheel help please
Old Dec 26, 2011 | 12:20 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
Default trigger wheel help please
ok heres the trigger wheel on my 2008 r1 its 24-2 in the settings in the emerald ecu it asks for the degrees before tdc it triggers judgeing by this picture it looks like 225 degrees??? can someone help me confirn this! should add the picture is of the engine at tdc on cylider 1 with the crank sensor at the bottom
Old Dec 26, 2011 | 12:45 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Cant you set it about right get it running then make sure 100% with a timing light. You would be able to dial it in 100% then
Old Dec 26, 2011 | 12:50 PM
clarke5700's Avatar
clarke5700
My reply confused me lol. On my mates starlet i fitted a trigure wheel wired in the ecu got the car running. The found true TDC and marked it. Then Made sure the ecu was firing 15* BTDC then set my snapon timing light to flash 15* BTDC and ajusted the settings in the ecu till my marks alined.
Old Dec 26, 2011 | 01:37 PM
taycoss's Avatar
taycoss
Handy pdf trigger wheel with angles here..........http://dtaforum.com/viewtopic.php?f=6&t=2
Old Dec 26, 2011 | 03:08 PM
stevieturbo's Avatar
stevieturbo
C**t
If the drawing is correct, and rotating clockwise. Then TDC is occuring 8 full teeth after the missing tooth.
360/24=15 x 8 teeth = 120deg
DixieTheKid
11
Jun 6, 2020 11:20 AM
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
