Sponsored by:
Sponsored by:
rear hub shims sierra? help??
Old 18-12-2011, 05:23 PM
SMILER258
SMILER258's Avatar
Question rear hub shims sierra? help??
Right, does anybody know if the bit circled in the picture acts as a shim for the rear hub? Or does it close the gap between the hub and trailing arm to stop crap getting in? if so would i need to make a new one as i dont particularly want a dust shield on the rally car. and mine are rotten.
cheers, Nathan
Old 19-12-2011, 04:58 AM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Could you not just cut away the dust sheild to leave the shim?
Old 19-12-2011, 07:13 AM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
its fine with out them i took mine off
Old 19-12-2011, 08:35 AM
Sonic Boom
Sonic Boom's Avatar
Same here took mine off too as they were rotton.
Rich
Old 19-12-2011, 09:17 AM
R4N SS
R4N SS's Avatar
you can get camber adjusting shims like that for not much money - i havent fitted mine so cant comment where they go - maybe Ade500 or rsmat can comment as they have them too
Old 19-12-2011, 09:38 AM
ajamesc
ajamesc's Avatar
ive never liked the look of them camber shims! as you would have to get the hub bearing carrier machined so the hub bolt heads can still mate correctly with there mateing faces on the bearing carrier with it now being at an angle with the shim in there
Old 19-12-2011, 09:42 AM
R4N SS
R4N SS's Avatar
yes but with the angle on a lowered car, it should in theory set the wheel completely straight on the floor - have a look at Ade500's pics of his 3dr with these fitted. He hastn drvien it yet so cant comment if it will be affected by movement
Old 19-12-2011, 10:01 AM
ajamesc
ajamesc's Avatar
Yeah but the 4 bolts that bolt the hub carrier the the rear arm will not tighten up against the hub carrier square with an angled shim inbertween the hub carier and the rear arm!
Old 19-12-2011, 10:55 AM
Moonstone Steve.
Moonstone Steve.'s Avatar
I have the rainbird shims on my saph, they seem to work well as i do get a good even wear across the width of the tyre.
Steve
Old 19-12-2011, 11:05 AM
andremarca
andremarca's Avatar
I've had camber schims on mine for 5 years now without a problem.
It made a great improvement in traction
Old 19-12-2011, 11:07 AM
BigErn
BigErn's Avatar
Ill be getting a set once the car is in the rebuild stage, they'll do till I save for a rear beam.
Old 19-12-2011, 04:34 PM
SMILER258
SMILER258's Avatar
Thank you for all your help, im just going to run the car without them. cheers, nathan
robbo9006
11
01-09-2015 02:10 PM
andyrs1600i
30-08-2015 07:21 PM
Ridgey
30-08-2015 08:37 AM
Vincereese
15-08-2015 06:24 PM
Vincereese
11-08-2015 08:44 AM
Quick Reply: rear hub shims sierra? help??
