spark plug recomendations fro 500hp?
Old 15-12-2011 | 02:13 PM
cozy777's Avatar
cozy777
Default spark plug recomendations fro 500hp?
advice whats peoples recommendations for a 4x4 coz engine 500hp ish, whats best spark plug/ heat range, ngk are one of my suppliers so can get these cheaper???????
Old 15-12-2011 | 02:37 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
071s all day, cheap good plug.
Steve
Old 15-12-2011 | 02:38 PM
R4N SS's Avatar
R4N SS
Steve
good as ive got a set to go in mine
Old 15-12-2011 | 02:40 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Not had any issues running them in mine
Steve
Old 15-12-2011 | 02:46 PM
R4N SS's Avatar
R4N SS
yep i never had any issues running them in my 3dr at 400bhp
Old 15-12-2011 | 03:12 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
071s are fine at this level of tune
Old 15-12-2011 | 03:16 PM
R4N SS's Avatar
R4N SS
and they're only around a tenner a set
Old 15-12-2011 | 03:33 PM
cozy777's Avatar
cozy777
Default plugs
lol something cheap and works on cosworth!!!!
no point going iridiums????? then???
Old 15-12-2011 | 04:36 PM
Mark Shead's Avatar
Mark Shead
No the 071 give a crap idle if you are running nice lean afr,
The Iridiums are 10times the plug imo.
Mark
Old 15-12-2011 | 05:27 PM
Gary F's Avatar
Gary F
071's are shit, cheap but false economy since they don't last that long.
Old 15-12-2011 | 05:58 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Mark
........spot on advice....i use NGK iridiums,quality plug that LASTS
Old 15-12-2011 | 06:13 PM
cozy777's Avatar
cozy777
Default plugs
do you part number of the ngk iridiums m8??
Old 15-12-2011 | 06:21 PM
Rax's Avatar
Rax
I used BKR9EIX in mine gapped at .65 but mine was no where near your bhp,it was only running greens .
Old 15-12-2011 | 08:06 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Iridium - pish unless you have a good coilpack setup, even then not worth the buck
071's - I also think they are shite....
NGK BCR 8ES all day long for me
Old 15-12-2011 | 08:18 PM
Rax's Avatar
Rax
I used iridium plugs in my bike with good results I suppose thats why I put them in my car.Same outcome on just a grp a coil,the only time they fouled was after sitting ideling for periods of time when the car was not in use (twice over a 12 month period).Other than that,use for 12 months then bin em.Its a pity Tabs is not about,he had a pretty good understanding of plugs imo.
Old 15-12-2011 | 09:18 PM
focus 4x4's Avatar
focus 4x4
071's running with a coil pack in mine , no faults whatsoever.
Old 15-12-2011 | 10:03 PM
COCHYN's Avatar
COCHYN
071's clog up easily, normally dead and unsalvagable in most cases. But the bang for buck you can't complain, its a good plug
Old 16-12-2011 | 08:48 AM
Gary F's Avatar
Gary F
I disagree, I really rate them and I'm only on a group A coil, and my car idles perfect and revs cleanly to 8500rpm.
Old 16-12-2011 | 09:39 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mine are about 18months old and still work fine
Steve
Old 16-12-2011 | 11:47 AM
Gary F's Avatar
Gary F
Steve
Yeah but how many mile have you done with them?
Old 16-12-2011 | 11:52 AM
BigErn's Avatar
BigErn
On the road or on the dyno??
Old 16-12-2011 | 12:44 PM
cozy777's Avatar
cozy777
decided on 071 for the running in period as there cheap and dont matter if they foul as cheap then will go to ngk's
Old 16-12-2011 | 01:01 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
About 2500 miles on each
Steve
Old 16-12-2011 | 03:24 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
If you dont have a good coil setup at 500bhp then you are stupid, dont blame the choice of plugs because your coil system cant cope . Iridiums of the correct grade at any horsepower & any boost.
Old 16-12-2011 | 03:51 PM
R4N SS's Avatar
R4N SS
i cant believe people are saying the 071s dont last long - well they're only a tenner so change them when they need changing
Old 16-12-2011 | 04:07 PM
BRAMMER's Avatar
BRAMMER
I have never had issues with 071 on wasted spark at all but since I've had a new engine I will be leaving that up to the mapper when the time comes but its currently sitting with a new set of 071 in for the running in process
Old 16-12-2011 | 04:15 PM
BigErn's Avatar
BigErn
Ive always used BCR8ES with no problems, granted not on a 500bhp engine but a 400bhp(ish) motor on greys and T34.63 @ 36psi. Never a missfire or hiccup, the only issue I had was if the car was being started, moved in and out of the garage/drive then turned off, then the same putting it away, it would eventually foul the plugs and it needed them cleaning and chucking in the oven for 10 minutes or bung a new set in at under a fiver (Halfords Trade Card )
Old 16-12-2011 | 04:44 PM
Gary F's Avatar
Gary F
Denso IK31's are the only plugs I'd buy now.
Old 16-12-2011 | 05:00 PM
B13 JUS's Avatar
B13 JUS
Rod, what's a good coil system for sm4?
Im using a coil pack and have to run a 0.5-0.6mm gap or I get blow out.
Is there a good coilpack I can use or will I need to go coil on plug?
Old 16-12-2011 | 05:32 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
071's for me, never had any issues with them at all.
Steve
Old 16-12-2011 | 07:40 PM
pete mcrash
...... BKR9EIX's........fuckn class plug....gapped at .75 faultless (and running 430 bhp )
Old 16-12-2011 | 10:12 PM
boost mad's Avatar
boost mad
What are peoples views on IK31s ?
Old 16-12-2011 | 10:57 PM
DAN400's Avatar
DAN400
i ve denso s in my car,
but my mapper changed them for mapping, he said he would nt put them in his lawn mower lol
once it was mapped he put them back in, i ve never had a problem with any plugs i ve ever run,
a mate of mines cossie eats plugs regularly for some reason
Old 17-12-2011 | 12:59 AM
R5FORD's Avatar
R5FORD
So he wouldnt put them in his lawn mower but put them back in your engine
Old 17-12-2011 | 02:58 AM
Paul_RS's Avatar
Paul_RS
NGK R7234
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
Brickhouse
14
03-10-2015 07:28 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: spark plug recomendations fro 500hp?
