Moving On
#41
Originally Posted by Itsmeagain
Originally Posted by ADUSR33
Originally Posted by Natalie
i noticed adusr33 has a japanese car - thats not very loyal to this website now is it ?
Too true..we dont love dem hoes
#42
Originally Posted by MADRod
Originally Posted by space hoppers
oh god wot you up to now then rodders ??????
the mrs has given you the go ahead then![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
I took her out for a ride & could only reach 192 on the ring road back straight, her comment I thought this was a 200mph car so she agreed I need more Power.
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
good luck in going for more
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
#43
rod if u reach 220 ill walk through manchester butt naked
Good luck geezer![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Good luck geezer
Rod
#44
Good luck geezer
Rod
#46
goodluck rod looks like your out to beat the rockets 205mph i recon you'll do it, you normally achieve your goal
Hardeep.
#47
Good luck Rod would be great for all ford owners if you could beat rocket ronnies top speed
Really hope you can do it
ADE(185.5mph) is not stoping as well he got more plans to go faster
#52
![Content](https://passionford.com/forum/images/smilies/content.gif)
Good luck with the build and the record attempt
#53
Good luck geezer
Rod
Best of luck Rod, you have only got to do another 4 mph? I'm sure you lot will sort that
#56
Your safe mate as you know, cant see a Cossie beating the Rockets 205.8 but will give it a go
u said b4 your inspeed 60-whatever times are quicker than ronnies so only really the 0-60 bit u losing to him on, and how much track does that use
Maybe a better mod rather than spending thousands on engines would just be to fit a parachute to leaving breaking even latter
Good luck tho whatever u do
Hopefully be reading about a new record soon
Steve
#58
May be just better to build another bit of runway on for this test lol. 205mph is going to be hard to beat at brunters, ronnies car has the advantage of the 4wd for the launch then switches to 2wd. Best of luck to ya
#60
DEYTUKURJERBS
I dont think Ronnies 4wd is much of an advantage TBH, it dont get him up to speed hugely faster, its at higher speeds where the acceleration is most effective, so more power and better aerodynamics will be the main factor if you cant brake later.
Rear diffuser etc to stop air being trapped behind the back bumper is an obvious one if its not already been done by Rod...
#62
The parachute ideas not bad actually...
Or some hydraulic rams to force the doors and bootlid wide open, airbrakes
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
This has been looked at already so may happen. Parachute not air brakes
#64
Originally Posted by tonyk
Are all the top speeds at brunters done from standing start or coming round the bottom bend?
The Rocket & Mike r did standing starts.
#66
Unless you are mega fast on the bend it makes no difference certainly its within 1 mph. With a semi -track car like Martins he may make it tell.
Oh shit i assumed all recorded Brunters top speeds were from a standing start
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
#67
Gwaaaaaaaannnn ya cooooooont
how about a mahoosive inflatable at the end so you can bounce back the way you just came and claim the reversing speed record
#68
Originally Posted by ImaRacing 700
How can it not make a difference?
If one car is already at speed coming out the bend compared to a bloke sitting on the straight from 0mph how can it be within 1mph?
Rod
#71
If that was in Basingstoke, I know where you did it! Fantastic bit of road.
Rather you than me!
#72
#73
#74
Unknown.
how much could we nick too
Good luck rod tho
#78
DEYTUKURJERBS
Originally Posted by Deano
Gary Passinghams GTR has done 211MPH at BRUNTERS so why mention Ronnie ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
![007](https://passionford.com/forum/images/smilies/bond.gif)
#79
To quote
" To test what this monster of a car was capable of, it was taken to Bruntingthorpe proving ground, two sets of timing equipment were set up near the end of a two mile straight. On each run the speed was increased and the car was checked, finally we reached a speed that was safe for the limited two miles we had, checked the times against each other and took the lower of the two. This was 211 mph, not bad for a car that you can use every day. "
That is taken from www.gtart.co.uk under projects
So take
#80
DEYTUKURJERBS
Ever heard the word LIES? ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Like him "claiming" theres ALS running on this car and more than a few us us calling BS on it as its obvious from the vid it aint
http://www.gtr.co.uk/forum/upload/sh...ad.php?t=33739
Originally Posted by Guy
Gusi,
Sorry to bring this is up again, and no dis-respect to Gary at all, but the 211mph is only what the speedo shows in the photo of the GT-ART car at Brunters. It was not measured either by GPS or timing beam (it was many years ago afterall).
Gary's car or Andy's cars would both be capable of speeds well exceeding 200mph, like many others, but have not yet had the chance to prove it properly.
Hopefully at some point there will be an event to prove the higher speeds, over a longer distance than the 1.25 miles used for TOTB. This really requires 1.6-1.8miles at either Elvington or Bruntingthorpe. However many cars will still not reach their max speed there, as true max speeds often takes several miles to reach.
Guy
Guy
