sapphire 4x4 oil leak
my cosworth is leaking a bit of oil from what looks like sump area, ive not got a jack to get right under car and car is sorn off road at min so can just see oil dripping of sump when looking under car, it could be sump gasket, oil pressure switch or the main real seal, if it was rear seal what sort of job is this? i know box has to come out but is it a fairly simple job?
box out is ok if you can get good access to underside, clutch & flywheel off & replace rear oil seal. |If sump is leaking there is no gasket, a bead of gasket sealer is all thats used
JoeyBoyden
18-08-2015 10:52 PM
st220kyle
16
14-08-2015 06:13 AM
