ford transit problem
Old Nov 30, 2011 | 03:01 PM
damien roe's Avatar
damien roe
Default ford transit problem
lad's i have a transit van 2001 2.4 rwd but it is down in power and hard on fuel at the moment. It's not of a cylinder or anything like that it fell's like the turbo ain't cutting in any idea's whats wrong
Old Nov 30, 2011 | 03:09 PM
andy130's Avatar
andy130
check for leaks in boost pipes, check the turbo aswel
Old Nov 30, 2011 | 03:31 PM
Karl 3dr's Avatar
Karl 3dr
Intercoolers are known to split on them as well occasionally. And turbo actuator rods can sieze
Old Nov 30, 2011 | 05:08 PM
rsturbolee's Avatar
rsturbolee
fuel filter, boost leak, cylinder head temp sensor, siezed wastegate, check turbos free read codes
Old Nov 30, 2011 | 05:11 PM
damien roe's Avatar
damien roe
no boost leak's checked that just no boost i think it is electrical problem soi think the temp sensor could be worth cheaking thanks mate
Old Nov 30, 2011 | 05:23 PM
andy130's Avatar
andy130
blocked cat?
Old Nov 30, 2011 | 05:26 PM
damien roe's Avatar
damien roe
Originally Posted by andy130
blocked cat?
how would you check that
Old Nov 30, 2011 | 05:28 PM
steve4i's Avatar
steve4i
take the 4x 15mm off the manifold and start it up and see if it revs up properly
Old Nov 30, 2011 | 05:41 PM
Karl 3dr's Avatar
Karl 3dr
Is there a loud diesel knock as well? They do suffer with the pump timing solenoids packing up, this causes lack of power also
damien roe's Avatar
damien roe
it rev's fine as is and under a tight pull (climbing a hill) there would be black smoke
Old Nov 30, 2011 | 06:15 PM
damien roe's Avatar
damien roe
now i hope it ain't that
i don't think she sounds to bad but i could be wrong
guy's would an egr valve do this
Old Nov 30, 2011 | 06:23 PM
Karl 3dr's Avatar
Karl 3dr
It's not as bad as it sounds if it is that mate, you can change the solenoid with taking. the pump off
Old Nov 30, 2011 | 07:06 PM
cosevo's Avatar
cosevo
mine was like that, was a load of water in fuel filter, changed and was back to normal
Old Nov 30, 2011 | 07:10 PM
damien roe's Avatar
damien roe
a nice easy fix
Old Nov 30, 2011 | 07:11 PM
damien roe's Avatar
damien roe
by the sounds i may get it plugged in to see what codes come up
Old Nov 30, 2011 | 07:32 PM
paddy heffernan's Avatar
paddy heffernan
heffo
Default down on power
mine was like dat turns out fuel filter was blocked.when i replaced it i got 100 km more on a tank of diesel.
Old Nov 30, 2011 | 07:52 PM
Karl 3dr's Avatar
Karl 3dr
P0149 and P1564 are the codes you are looking for, tbh though, it's normally slightly later vans that suffer with that problem
Old Nov 30, 2011 | 07:55 PM
damien roe's Avatar
damien roe
thanks mate i'll give it a filter change and see how it go's but i know it won't be that simple
Old Nov 30, 2011 | 08:46 PM
wulliesxr4i's Avatar
wulliesxr4i
GIT-R-DONE
had similar problem with a tranny b4 changed the egr valve and it was fine could b that mate,
Old Jan 14, 2012 | 08:11 PM
damien roe's Avatar
damien roe
right guy's i got an hour on my transit today and when i take the vacuum pipes of the little black switch screwd to the rear of the slam panel on the passinger side(its something to do with the egr valve) it drives twice better
Old Jan 14, 2012 | 08:44 PM
twister's Avatar
twister
Get it plugged in cause guess work does'nt work .
Old Jan 14, 2012 | 08:49 PM
andy130's Avatar
andy130
pic of damein?
Old Jan 14, 2012 | 08:57 PM
damien roe's Avatar
damien roe
this thing
http://www.ebay.co.uk/itm/EGR141-FOR...item45fde4d839
Old Jan 15, 2012 | 11:55 AM
andy130's Avatar
andy130
sounds faulty, try a new one on it see if it goes any better
Old Jan 20, 2020 | 08:10 PM
Ryan paving's Avatar
Ryan paving
Default I've a similar problem
p0149 and p1564 codes coming up.Ive checked the timing solenoid seems to be fine.Anyone have any solutions.
Dr. Ickxs
Aug 15, 2015 11:34 AM
Mark RS
14
Aug 11, 2015 11:45 AM
Fil
14
Aug 10, 2015 07:42 PM
vdubo7
Aug 2, 2015 08:17 PM
