Any hgv fitters on here
Help required on ghanging twin plate clutch on renault premuim, done the job just carnt get the clutch to clear so can engage gears, if you pump the clutch you can get a gear but bites at the floor, have bleed clutch and adjusted the rod on the slave clyinder but still no avail. Plz help ta rich
the whole clutch kit came preassembled with four holding bolts so just bolted it up, but after the second time i pulled the gearbox out i pulled it all apart and its all been bolted up right, going to try a genuine renault clutch tomorrow
Problem solved . Put a genuine Renault sach clutch in bolted all back up and set slave adjustment to where it was originally and it's perfect. Thanks for the help. Lessoned learnt never get a cheap and nasty clutch lol.
Stavros
12
24-11-2005 11:34 PM
kevsrs
16-11-2004 07:21 PM
