can u run a boost controller and bleed valve in series
ie run the bleed off pipe off the boost controller through the bleed valve so i cant go over the set amout of boost the car was set up for
cheers(soz if im been stupid it late lol)
Carbon Crazy
I dont get what that will achieve. the purpose of a boost controller is to bleed off measured amounts of boost so that the actuator works at whatever boost you want.
a bleed valve does the same except its a mechanical valve.
running both in series is likely to make you EXCEED your set up boost. Think about it, you now have introduced 2 holes in the pipe leading to the actuator, so more air is bled off before the actuator "sees" enough boost to work.
na turbo systems chip ment for a t34 mate, greens, group a k&n , full exhaust system, 3 bar, and soon to fit a front mount running standard 4x4 cooler at min, and cr turbos st3 t3
gchristophi
31-08-2015 10:36 PM
Escortdriver1
31-07-2015 02:36 PM
