who to do some electrical work on my escos..??? UPDATE!!
Old 20-02-2005 | 03:17 AM
DaveEscos's Avatar
DaveEscos
Default who to do some electrical work on my escos..??? UPDATE!!
car has died,
has ignition and fuel pump feed
i think its the ecu or fusebox?
who is good at electrics on these that can come over for a job
i pay well!
f*king car!
Old 20-02-2005 | 04:39 AM
CozzyBrom's Avatar
CozzyBrom
who good is pay well
i know the problem
Old 20-02-2005 | 10:02 AM
Matt's Avatar
Matt
you been trying to find the prob until 3am dave
that london is a bit far for the claw or im sure hed help
move up north you southern shandy drinking bastard
Old 20-02-2005 | 10:07 AM
TIFF's Avatar
TIFF
Chasing Radders
I had Dingy come to my house to sort the 3DR out a while ago and all is fine now
They say Money Talks Dave, get ya cash out and Tempt to Claw down to you
Old 20-02-2005 | 10:10 AM
Matt's Avatar
Matt
Originally Posted by TIFF-C20WTH
I had Dingy
so it is true what bubba says then
Old 20-02-2005 | 10:11 AM
TIFF's Avatar
TIFF
Chasing Radders
Indeed Mathew, and he didnt even touch the sides
Old 20-02-2005 | 11:17 AM
GARETH T's Avatar
GARETH T
i hope you sort it dave,, its a little far for me,, unless i would come for a nosey
Old 20-02-2005 | 11:33 AM
DaveEscos's Avatar
DaveEscos
not to 3am Matt, i'd just got in with the car on the back of a low loader!
on cranking the car, there was no power to the injectors or the chg temp sensor so im guessing all sensors
secs monitor shut down as well
and i need the fuel pump wired up so it primes and then switches off on the ignition click of the barrell
its priming constantly at the mo
Old 20-02-2005 | 11:55 AM
DazC's Avatar
DazC
Dave, have the multiplugs for the engine loom been removed?
Old 20-02-2005 | 12:42 PM
DaveEscos's Avatar
DaveEscos
no Daz
can someone give me a guide to what pin does what on the ecu ??
Old 20-02-2005 | 01:22 PM
ECU Monitor Enthusiast
Dave, where abouts are you in this land of ours ??
Old 20-02-2005 | 01:23 PM
DazC's Avatar
DazC
I think this is all correct. Had to get it from my diagrams which are not that easy to follow...
pin 1 earth
pin 19 earth
pin 2 lambda sensor
pin 20 positive power feed
pin 3 crank pos sensor
pin 21 not used
pin 4 crank position sensor
pin 22 knock sensor
pin 5 distributor connection
pin 23 distributor connection
pin 6 knock sensor with earth bonding sheild
pin 24 ignition module pin 3
pin 7 canister purge valve
pin 25 ign module pin 6
pin 8 electronic control loom
pin 26 not used
pin 9 linked to pin 30 (MAP and throttle pos)
pin 27 electronic control loom
pin 10 EFI power delay relay in fuse box
pin 28 fuel pump relay
pin 11 map sensor
pin 29 coolant temp sensor
pin 12 not used
pin 30 map sensor and throttle pos sensor
pin 13 octane adjust
pin 31 air charge temp
pin 14 octane adjust
pin 32 injector 2
pin 15 map sensor
pin 33 injector 3
pin 16 boost control valve
pin 34 idle speed control valve
pin 17 throttle pos sensor
pin 35 injector 1
pin 18 injector 4
Old 20-02-2005 | 01:35 PM
DaveEscos's Avatar
DaveEscos
Daz, appreciated mate
Si, apparently 150 miles from your mcdonalds
Old 20-02-2005 | 01:42 PM
DazC's Avatar
DazC
Originally Posted by DazC
pin 1 earth
pin 19 earth
Check these pins. Power on 20 and earth to chassis on the other 2.
On the Escort it takes it's power feeds from one common soldered joint... VS-1229....but I can't locate this joint in the diagram....I am still looking...
Old 20-02-2005 | 01:53 PM
Turbo lag's Avatar
Turbo lag
Dave did you get my pm ?
Old 20-02-2005 | 01:56 PM
DaveEscos's Avatar
DaveEscos
cheers Daz
Dave, i have received a few pms, but ove been so focused on the car this weekend i havent checked them out yet, ill look now
Old 20-02-2005 | 01:57 PM
DaveEscos's Avatar
DaveEscos
just checked it
speak to cossymad abut the coilovers, he specced mine so can do the same as yours
and the ride quality on soft is no harsher than my old koni's
Old 20-02-2005 | 02:03 PM
DazC's Avatar
DazC
Dave,
Fuse 3 feeds the ECU, injectors and varius sensors and valves.
Relay 8 is the power relay for the management system.
Fuse 25 feeds the fuel pump and also feeds fuse 3...
If the ECU has lost its earth then the management relay won't work....
Ryan's Avatar
Ryan
dave where abouts are you again?
Old 20-02-2005 | 02:10 PM
Ryan is the man sorted me out with my elecy gremlins andhes doing more next week
Old 20-02-2005 | 02:13 PM
DazC's Avatar
DazC
Relay 9 is fuel pump...
Fuse 5 is fuel pump.
Old 20-02-2005 | 02:54 PM
DaveEscos's Avatar
DaveEscos
cheers Daz, ill check those now
Ryan, im near Dartford.. not too far from you
Old 20-02-2005 | 03:46 PM
Ryan's Avatar
Ryan
lol
let me know if you dont get it sorted.
I'm sure we can sort something out
Old 20-02-2005 | 04:00 PM
DaveEscos's Avatar
DaveEscos
right, UPDATE
pin 20 is only getting 8v!
i fed a feed direct from the battery to the pin, voltage 12.18v started the car and
she burst in to life
so that narrows it down to that cheers all
now... why is the ECU feed low on voltage?
where does it feed to?
its a blue cable with a yellow stripe
Old 20-02-2005 | 04:23 PM
Ryan's Avatar
Ryan
glad you narrowed it down mate
you got the wiring diagrams to check?
Old 20-02-2005 | 05:03 PM
BillyCabrio's Avatar
BillyCabrio
Dave, speak to TT or Damo and get that auto sparky number of the fella that done TT's motor.
I hear he's the dogs hanging bits.,.,
Old 20-02-2005 | 05:28 PM
DaveEscos's Avatar
DaveEscos
darren?
hes the bloke that fitted my alarm and quite possibly caused this!!
Old 20-02-2005 | 05:41 PM
BillyCabrio
Erm i dunno his name mate? Could be - but i'd be surprised if it was tho?
Hope ya get it sorted...
Old 21-02-2005 | 01:57 PM
Matt's Avatar
Matt
possible loom issue?
dont escorts have a 2 part loom ......with a connection thats prone to causing such things?
Old 21-02-2005 | 02:56 PM
Ryan's Avatar
Ryan
yeah mate at the back of the cam cover.
Old 21-02-2005 | 03:05 PM
Disabled Account's Avatar
Disabled Account
Dave,
I hav'nt read the whole post...
BUT it is very important that you check the two multi-plugs on the main engine loom........these are situated near the righthand side inner wing near the coil.
If you take the connectors apart, you may well see corrosion/grey/green residue on some (or most) of the pins.
The remedy (temp) is to clean all of the pins......Better still for the long term, is to do as Steve C and others have done - replace the multi-plugs by direct wiring/sleeves
Old 21-02-2005 | 03:11 PM
Ryan's Avatar
Ryan
or get a new loom
St3V3_C's Avatar
St3V3_C
.... on a saph.
On the inner wing by the coil on an escort
Old 21-02-2005 | 03:13 PM
Ryan's Avatar
Ryan
ahh ok
Old 21-02-2005 | 03:18 PM
DaveEscos's Avatar
DaveEscos
Doug et Ryan
The car has had the multiplugs removed and joints soldered as a means of course years ago.
Why on earth would the power feed to the ecu be reduced to 8v???
Looks like dash out to trace the wire back.
couldnt i just rewire a feed to the ecu? is it ignition based or perm?
im guessing the ecu retains memory so it will need a perm feed all the time.. but this activates the fuel pump etc...
what voltage is PIN 20 with ign off?
Old 21-02-2005 | 04:19 PM
Ryan's Avatar
Ryan
Dave, Pin 20 Is a Live feed from the Power Relay, so i pressume its triggered by the relay on (ignition on) and thus is not a direct constant 12v Feed.
I will double check though
Old 21-02-2005 | 07:35 PM
DaveEscos's Avatar
DaveEscos
ok ryan, well all i need to know is ..
which relay in the fusebox? theres loads!
anyone??
Old 21-02-2005 | 07:50 PM
wes's Avatar
wes
Not sure about an escort, but on all sierra models the 2 relays (ECU power and Fuel pump) aren't in the fuse box, they are located nearer the ecu connector.
Old 21-02-2005 | 07:53 PM
Ryan's Avatar
Ryan
let me check in a sec as i got a couple of spare fuseboxes in the garage, its not the same car granted but might narrow it down.
Old 21-02-2005 | 07:55 PM
DaveEscos's Avatar
DaveEscos
Quick Reply: who to do some electrical work on my escos..??? UPDATE!!
