escort rs turbo ecu's?
Just brought my self a g reg series 2, now iv been told its got the wrong ecu on it. i was told it should have and ecu with hearts and diamonds on it, mine has the coloured squares on it. i was told that that ecu is from a series 1 is this right and will it make a difference?
st170 breaking
blue red blue is a common s1 ecu, it wont matter either way what you have, i found a box with 15 rs ecu's in the yesterday,
some peopl3 say a series 1 is best ecu as it allowed 1psi more and had no knock sensor, i may be wrong but i think you have to disconnect the knock also otherwise it was im permenent knock/safe mode
i could be talking crap its been a very very long time sice i used kejetronic stuff
st170 breaking
yam yammer
How's it goin Rob? From the factory it should have a hearts and diamonds ecu. They will run slightly more boost than the earlier coloured ecus. I think most are interchangeable tbh, just check your base idle and ignition timing.
Later ECU's need a knock sensor, or will run like a bag of shit. S1 or V early S2 is the best as no knock sensor, the knock sensor circuit very often removed timing for fun.
after pissin around for ages with no joy trying 2 get my car running better im back to the ecu, mine is a blue, red, black. Which is for series 2s with a knock sensor (late 89s and early 90s) from what ive found out on here. but my knock sensor is not pluged in. could this be the problem? Thanks Rob.
muz
16-08-2015 12:57 PM
