were do i plug in cold cathode lighting in pc???
got a pc with a merc case, its got two multi coloured neon fans on side with big perspex window
ive got 2 x 12 " cold cathode lighting tubes that came ina box with switches and pplugs etc, think they are for a pc specificly so shouldnt be hard?
I'm going some on your questions today
It will probably have a sort of inline connector with a four pin socket and a four pin plug that you put in between the hard drive or CD drive power connectors.
Otherwise, you need to solder / splice / scotchlock the positive for the cold cathode into a yellow wire on the hard drive / CD drive power connector and the negative into a black wire.
wheelwizardrefurbs
24-09-2015 08:35 PM
