Best way to set up a new cossie cambelt?
GASH!
Hiya, tomorrow my cossie cambelt goes on if it all goes to plan, but whats the best way of setting the tension? it says in the workshop manual you need a special tool, but is there a way of doing it?
Mike.
Mike.
when fitted correctly ,you should be a ble to twist the belt on the long side,
about 45degs.
Best to fit the belt and then rotate the engine a couple of times before finally
checking the tension.
Don,t forget that the tdc mark is the back edge of the ign pickup point
on the bottom pulley,nearest to the firing mark on the pulley.
cheers,puddy
about 45degs.
cheers,puddy
i found mine was noisy at 45deg, slackened it off to a tight 90 deg and its
its a bit of suck it and see
whatever you do torque the tensioner correctly i have pulled the thread on 2 of them and one cost me a rebuild
HTH
Pugo
HTH
Pugo
Escortdriver1
01-11-2015 07:55 PM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
