Cooling problem
Old Nov 7, 2011 | 05:22 PM
ballin's Avatar
ballin
Default Cooling problem
Hi guys,
Got a problem with a BMW 318 (m43 e46), the cooling system used to pressurise so much that it created leaks, until one day it just blew a hose apart.
I replaced head gasket assuming it had gone and was pressurising the cooling system, and now after putting it all back together I discovered the outlet from the thermostat housing is not getting warm or pressurised, whereas the top hose is (mega hot, mega pressure), therefore I assumed thermostat stuck shut.
I just replaced that and it's still doing the same thing, thermostat outlet remains cold pretty much, and the top hose gets so pressurised I have to keep the cap off. After running it a while to see if the stat would open I finally gave up and switched off, at which point the coolant just started to belch out of the header tank so god knows whats going on inside!
All I can think now is the water pump? How can I test if it's working?
Engine running and cap off, there is no water flow that I can see. If I rev the engine it starts to circulate.
At a bit of a loss really, any advice or tips of what to check?
PS. temperature needle never goes beyond normal, nor did it before it blew hose apart - though it did after, so the sensor works!?
Chas
Oct 5, 2015 07:13 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
