chipped fins on turbo
I just took the pipe from the air box into the turbo off and the blades are all chipped badly,there is no play up and down in the blades and they are still spinning smoothly
I assume this is the cause of my recent lack of power?-will i just need to change the turbo or could there be a lot more damage done to the engine-it happened because moisture got into the system and destroyed my air filter
Here should be a link to the photo
https://passionford.com/forum/album....ictureid=22131
I had and it was only in around 2 months! It was damp and fell apart with 2large rips in it
Like something bust through it
It Wasnt Me!
Yep that's pumped!
Could send it off for a re-con to be 100% sure, buying 2nd hand IS a gamble, but that's why 2nd hand turbo's are cheap...
give CR Turbo's a call and see what they can do for you, explain you think the turbo is fine other than the compressor wheel is shot (this could have thrown it out of balance and damaged more but you won't know til it's in bits)
JK12
33
26-04-2021 12:09 PM
big_Rad
15-09-2017 09:36 AM
cossie09
11-10-2015 06:32 PM
Matt Baxter
16-09-2015 08:30 PM
cossie09
14-09-2015 04:21 PM
