my xr3i efi has a pretty bad engine judder when driving
hi people can use help me. my xr3i
(efi) has got an engine judder pretty bad when driving, its fine when ticking over or if u rev it its fine jst when driving, what could this be? the engine has just been rebuilt too......
1 Post
or just put the car on a diagnostic machine at a local garage, might cost £40 depending on where you are
Originally Posted by tommytwotanks;[URL="tel:5680137"
5680137[/URL]]have you done any tests to see if you can norrow it down, like reving it until it misfires and then taking a plug lead off, then swaping a plug to see if the misfire moves, you could do the same with the injectors
hi, Ive not long had the engine rebuild new plugs and leads last week new clutch and gearbox. do you think it could have anything to do with the fuel relay or fuel pump? or anything else? any info is much appreciated thank you
hi, Ive not long had the engine rebuild plugs n leads were done last week. gearbox and clutch recently fitted. its kinda got a flatspot too and juddering. its jst whern its driven and on tick over its ok and ok when you rev it, do you think it could be down to the fuel relay or fuel pump? any info you can give me is much appreciated thank you
1 Post
do you think it could be a blocked injector
track.focus'd
12-08-2015 05:53 PM
Archiejay
12-08-2015 12:07 PM
