Actuator Help *****
Old Feb 18, 2005 | 04:49 PM
Andy.B's Avatar
Andy.B
Default Actuator Help *****
Soz for postin in the wrong forum but im re-fitting my turbo and want to know what the rule is for the actuator???
Is it wind in = More boost
Wind out =Less????
Thanx
Old Feb 18, 2005 | 04:54 PM
lancia delta 6 times WRC's Avatar
You shorten it for more boost
Old Feb 18, 2005 | 04:57 PM
Andy.B's Avatar
Andy.B
Good stuff, ill go fit it now
Old Feb 18, 2005 | 05:49 PM
Dean Saff's Avatar
Dean Saff
I would have to say you would be best putting it on loose and get it set up by someone in the know...you could end up blowing your engine if you do it wrong and just take a guess at it..
Old Feb 18, 2005 | 06:24 PM
Andy.B's Avatar
Andy.B
Tis ok mate its only for a Diesel, it was running 20 psi bit i wanted less, so would it out for a lil less boost
Old Feb 18, 2005 | 06:39 PM
Dean Saff's Avatar
Dean Saff
Dont understand what you mean wind the actuator out unless you mean you have a bleed valve fitted in which case you wind it in for less boost
the actuator arm needs to be made longer but you will need to unhook the arm from the wastgate to do this, otherwise you will damage the actuator.
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
