ARP torquing problem
Old Oct 11, 2011 | 12:10 PM
Dennis_Wiseman's Avatar
Dennis_Wiseman
Default ARP torquing problem
Building up a Zetec Turbo silvertop.
The ARP rod bolts i have come up on the ARP site as 'general replacement' torque to 55 lb/ft.
Having looked at some random builds, ARP 'Zetec pacific' bolts seem to be only 25 lb/ft.
Quite a large difference in settings
What should i torque to?
Thanks
Old Oct 11, 2011 | 04:10 PM
Dennis_Wiseman
Anyone ??
Old Oct 11, 2011 | 05:45 PM
Icurus's Avatar
Icurus
What part of the engine are these for?
I have only used ARP bolts for my engines con rods, and torque'd them upto Fords recommended setting, but using ARP's method.
Old Oct 11, 2011 | 05:50 PM
Rs1's Avatar
Rs1
You'll need to know the sepcific bolt specs aswell as conditions(dry, moly'd up etc). There will also be a difference going into OE rods and steels.
Old Oct 11, 2011 | 07:32 PM
Dennis_Wiseman
Its for conrod bolts. The code number of the arp's is 200-6209
55 lb/ft seems a hell of a load compared to the factory spec or zetec specific ones.
Forgot to say, their for Pec rods. Got the pistons and rods with the ARP's as a package
Old Oct 12, 2011 | 12:05 AM
stevieturbo's Avatar
stevieturbo
C**t
WTF are "Zetec pacific" bolts ?
Torque generally goes by fastener size. So what size are they ? Must be M9 or M10 or thereabouts ?
Old Oct 12, 2011 | 12:17 AM
botters's Avatar
botters
competant bodger
i may be wrong but arnt arp's stretch bolts? if so this would explain the higher torque setting although the setting you have mentioned doesnt sound overly tight for rod bolts
Old Oct 12, 2011 | 12:22 AM
stevieturbo
C**t
You are indeed wrong.
Whilst in reality all bolts will stretch when tightened, ARP do no make what are normally termed stretch bolts.
Old Oct 12, 2011 | 12:28 AM
botters's Avatar
botters
competant bodger
ah well just remember reading on an arp packet that x amount of torque was required for x amount of stretch!
even so, as said above that torque setting doesnt sound rediculously high a lot of rod bolts are similar settings then a x amount of degrees setting as well
Old Oct 12, 2011 | 07:46 AM
Dennis_Wiseman
These i have are ''general replacement''
ARP do pacific ones for your car
Old Oct 12, 2011 | 08:21 AM
stevieturbo
C**t
The Pacific is an ocean.
specific is something completely different
Old Oct 12, 2011 | 11:54 AM
Dennis_Wiseman
hahah fucks sake
Old Oct 12, 2011 | 02:05 PM
Churtz's Avatar
Churtz
Arp rate their bolts to be tightened to a specific stretch....not torque!
Old Oct 12, 2011 | 05:23 PM
Icurus's Avatar
Icurus
Bolts can be set by in number of ways, torque, angle or stretch are the ways that I have heard of, you may know of more.
ARP do recommend the stretch method, but not many people have a stretch gauge to hand, but hopefully they will have a torque wrench which will suffice for engines being built for a fast road car.
It is also important, as has been mentioned above, to torque the bolts with the threads prepared to the bolt manufacturers recommendations, and the torque procedure followed to the letter.
Old Oct 13, 2011 | 08:11 AM
Dennis_Wiseman
IIRC, Standard spec is 25 lb/ft, ARP Zetec bolts are 35 lb/ft with lube and these i have the code number says 55 lb/ft.
If your meant to go by bolt spec rather than car / rod spec then im probably better torquing to the indicated 55 lb/ft ?
Old Oct 13, 2011 | 09:03 AM
stevieturbo
C**t
Torque to ARP's specs using the correct lube unless someone intelligent has stated otherwise.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
