rs turbo boost
rs turbo boost
hi there peeps iv been to have alook at a rs turbo today and had a drive of it and im looking to buy it but when i was driving it i saw the boost gauge was running at -5 bar on idle is that ok for it to be like that and when i put my foot down i can here the turbo going up but did not dump the air on gear change it has got a dump valve just didont no why this is ?
I need to add freon to my car but do not have a machine to measure freon I need to use guages and pressure readings I have a chart that shows correct pressures adjusting for outside temp and humidity but I need to know what will the guages show when the car is low on freon will the low side be too low and high be too low if it is low on freon and what will show if it is overcharged..
yes, normal. (assuming you mean -0.5, not -5!) it won't make positive boost until later in the rev range. (which presumably you saw when you put your foot down? if it stayed at -0.5 bar or didn't go above zero then walk away!
dump valve might be recirculating if you can't hear it.. either that or just quiet.
no idea what the other bloke's on abotu though!
Martin
Matt Baxter
16-09-2015 09:30 PM
gchristophi
31-08-2015 11:36 PM
CrOwSoN15
18
22-08-2015 11:24 PM
Escortdriver1
31-07-2015 03:36 PM
