Front brakes binding on when hot
I've just braked really hard from about 100 down to 30 several times, and the front brakes were stuck on, the brakes are KAD 6pots on 355mm disks and half worn pads, I've got a modified sierra pedal box. I've struggled home and cooled them with 8x buckets of water which freed them up straight away.
As precaution ive removed the pads and cleaned the pistons making sure they're all free moving and no dirt on the piston seals. They work fine still so I was wondering what could cause this? Obviously as they got hot everything expanded and they rubbed more and it expanded more etc etc, could the fluid have boiled and expanded too, can pistons stick when hot? It just wouldn't roll even with 240 bhp behind it. I have no extra brake ducting and it was super hot out but that still shouldn't happen I can't have this happen again, so some ideas please people!
long shot but have the flexy pipes collapsed internally. i had this on a car years ago. other than that check abs valve block. i cant see a problem with cooling as a six pot calliper should be able to cope with 100mph comfortably.
