Cossie 370bhp @ 14psi
Old 01-10-2011, 11:49 AM
  #81
J1mbo
B1mbo
J1mbo's Avatar
YOur such a tosser
So what your telling me is, when you put your foot down, (when were talking about spread of power and torque) your not actually using full throttle but now were talking about part throttle?
Your probably right in that case, that tyhe smaller cam combo will be better, I'm talking about full throttle spread of power and torque though
Old 01-10-2011, 11:56 AM
  #82
J1mbo
B1mbo
J1mbo's Avatar
Pmsl I love your stories, (not the one about the ex though please, I don't have all day!)
Your bang on! I wasn't talking about that though, I'm on about full throttle
Old 01-10-2011, 12:01 PM
  #83
Moonstone Steve.
Moonstone Steve.'s Avatar
Originally Posted by Tony Mannock
jumbo you are such hard work
you are sat at the lights on the way to aldi it's on a hill you go to pull off and it won't
because the 16 14 combination has no off boost torque what so ever
it will however pull off once you have activated the clever pectel start line strategy nailed the throttle to the floor activated als hit 6k rpm and 1 bar of boost and smoked the fooker for the next 500 yards
I need some of this
Steve
Old 01-10-2011, 12:05 PM
  #84
Moonstone Steve.
4wd head or 2wd head Moanycock?
Steve
Old 01-10-2011, 12:26 PM
  #85
J1mbo
B1mbo
J1mbo's Avatar
these are road cars jim using your suggested cam combination will ruin the guys road car when what he actually wants is a fast road car not a race car
nothing wrong with your theory though jim because then you can charge him to change his engine spec when he comes back roflol
jim you are young and spotty there is no way we are going to believe that you can drive a t4 powered yb with 550bhp and laggy cams on full throttle
I'm not one of your matess down at mcdonalds lol
The guys looking for over 500bhp and to kick its head in up the motor way, I wouldn't tell him to use cams that would be absolutely diabolical, its not just cams as you know but how you time them, but, obviously he's your customer, you can do it, and can you stop calling me young and spotty pmsl
Ps, Mine will be having exactly that and I'll be driving it full throttle most places to start
And stop taking the piss!
Old 01-10-2011, 12:51 PM
  #86
J1mbo
B1mbo
J1mbo's Avatar
Fpmsl
Mike says your a big boy, I'm sure you can take care of yourself
Old 02-10-2011, 09:48 AM
  #87
martysmartie
martysmartie's Avatar
Originally Posted by cozmeister
The new gaskets and new bolts don't make the power though
What flavour injectors are on there...? As for the "old shitty ford ECU" comment, there's nothing stopping one running a much more powerful engine, after all, all it does is calculate when to inject fuel and fire a spark, and their "old shitty" 8 bit processors can do that in their sleep
Always find it funny how people assume that because something's old it's automatically incapable of doing something it was actually designed to do.
So true, just because something is newer does not automatically mean it's better!
Modern ECU'S in the main just have the capability to run extra gismos natively it's akin to say a Nokia 5110 and a N95, they both achieve the same fundamental end result, i.e. being able to make and recieve calls, it's just the latter can do alot of other NON essential stuff as well!
Martin
Old 02-10-2011, 10:05 AM
  #88
scoooby slayer
scoooby slayer's Avatar
Originally Posted by SiZT
Wrong, AET's Dynapak reads at the hubs, so is it who gives a shit about whp now??
By the way, your probably around 330bhp. Congratulations, you've spent shit loads for stage 3 power
i think that more than sums it up tbh, on these hub dynos just add about 10% for a realistic engine power figure, and add 17.5% to dd whp.
makes this gt28 car 300 hub power, 330 engine hp which is about right.
every time i see these figures it tallies up from a hub dyno to dd, or these cars are magical and making power from nowhere lol
Old 02-10-2011, 10:36 PM
  #89
fezzy240bhp
fezzy240bhp's Avatar
still doesnt answer why its only doin 14-16 psi and getting that power and its not just on the dyno pak its on my boost gauge aswel ??
Old 03-10-2011, 08:52 AM
  #90
cossie4i+
TT T38 Power
cossie4i+'s Avatar
You still haven't told us what injectors you are using or posted your graphs.
Steve
Old 03-10-2011, 10:29 AM
  #91
SiZT
SiZT's Avatar
Quite easily tbh, a friend of mine's car makes 267whp on a GT28rs (po-ta-toe) at 15psi on a 1.6 SOHC 16-Valve engine. So bigger capacity, bigger turbo should see you doing 300 at the hubs
Old 03-10-2011, 12:20 PM
  #92
cossie350
cossie350's Avatar
Is there such a thing as a 1.6 SOHC 16v engine or is that a typo ?
Old 03-10-2011, 01:54 PM
  #93
cozmeister
More boost Igor!
cozmeister's Avatar
Don't think there's a Ford one, but the Laguna I had at work was a 2.0 16v SOHC, and my ex's Mazda is a 1.6 16v SOHC.
Old 03-10-2011, 03:53 PM
  #94
Marc sierra
Marc sierra's Avatar
Originally Posted by RigPig
http://smg.photobucket.com/albums/v2...t=dynorun1.jpg
Found my old dyno sheet, this was on a gt28
That looks very good! Isn't it quite extreme to already have almost 290 lb-ft at 2500 rpm and still be able to do as good as 400 bhp? I suppose the bhp figure can be had with a T34.63. But that turbo will never make as much torque at 2500 rpm.
What's the spec of that engine, if you don't mind telling?
Old 04-10-2011, 01:13 AM
  #95
Dingy
Dingy's Avatar
My car made 389 at 1 bar mate....
T4
Old 04-10-2011, 06:00 AM
  #96
cossie4i+
TT T38 Power
cossie4i+'s Avatar
T4
Im sure a T4 is a far bit bigger than a GT28 so will flow more at the same boost level.
Steve
Old 04-10-2011, 06:03 AM
  #97
Dingy
Dingy's Avatar
I know mate - just stating the obvious
Old 04-10-2011, 05:59 PM
  #98
TimC
TimC's Avatar
I bet if that was 4wd and had 3.9 diffs it would be an absolute hoot on the road. Effortless punch coming out of corners.
Old 04-10-2011, 07:17 PM
  #99
J1mbo
B1mbo
J1mbo's Avatar
Even better 2wd!
Old 04-10-2011, 07:25 PM
  #100
TimC
TimC's Avatar
I think unless the suspension is set up perfectly, that much torque that low down would be a pain in the ass trying to get it to hook up from lower speeds. Would be alot of fun, but not as fast as 4wd down a tight twisty road.
Old 04-10-2011, 07:31 PM
  #101
J1mbo
B1mbo
J1mbo's Avatar
Cossies IMO are about putting a smile on your face where you use them most, by me thats mainly coming out of roundabouts and just being s muppet tbh lol
If I wanted to be quick round cadwell, your right that would be sweet through the twisty sections!
Old 04-10-2011, 08:07 PM
  #102
cossie350
cossie350's Avatar
If I wanted to be quick round cadwell, i would by a peugeot or renault!
There you go mate !!!! Spot on
Old 04-10-2011, 08:23 PM
  #103
J1mbo
B1mbo
J1mbo's Avatar
I'd like for it to last a lap and not die with electrical problems though fella??
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: Cossie 370bhp @ 14psi
