these non running transits
st170 breaking
what is the problem?
i want a tranny and see dozens around just stopped running, i also hear of repair bill sinto 4 figures and still not right
i like the silver 1 below alot too
so far i heard you replace the diesel pump and taht it doesnt need recoding if you keep the same electronic parts?
some examples
http://www.ebay.co.uk/itm/2508970978...84.m1423.l2649
http://www.ebay.co.uk/itm/3207639721...84.m1423.l2649
http://www.ebay.co.uk/itm/2906136490...84.m1423.l2649
some examples
As above, the pump needs coding to the ecu, some sort of anti theft thing?
And I would have thought you'd need to get the injectors coded to the pump, as its a calibration thing, so that the correct amount of diesel is sprayed etc.
Ford do a kit injectors and pump for bout a grand plus u still gotta get it coded tbh when the they go there reli not worth fixing. have you looked a citreon relays ? and that sorta van ?
st170 breaking
ive had a 57 and now on a 10 plate but want my own, tbh i give mine hell and it works fine
my old 57 plate ie being driven but a mate who spends most of his time flat out and apart from not charging right its fine
i do like a transit, not indo owt else, i did drive a vivaro the other day that went well but its the only 1 i have and ive driven loads of them
these pumps are rubbish huh, with old escorts you could remove the coded bit and fit the older uncoded and off you went
are there any other vehicles these parts can come from?
The only pumps that need coding are the early Di Transits (i.e non common rail) because the PATS is built into the pump, the TDCi (common rail) ones don't need coding, although the newer ones need to be run through a "pump learn" procedure using IDS. Similary, the Di injectors don't need coding, they are a simple replacement job, but the TDCi injectors have got a 16 digit correction factor stamped on them that has to be programmed to the ecu using IDS if they have been replaced.
st170 breaking
so with a new or suitable pump its no big hassles
i have get ids stuff done on the side if i leave it with em
i do like the silver transit with the swivel captain seats
Eigdoog
13-09-2015 05:46 AM
