how do i check a drain from the battery....
further to lots of other threads, i need to know some specifics for you audio type peeps
i need to check that my amp, wired directly to the battery, isn't draining the battery
how do i do this?
it's obviously got a direct feed so when i put my meter to the power side it lights up, but after that, i don't want to blow anything up so i've sort of stopped
and the kids are doing my nut so i can't concentrate either![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
so, probe to the earth side should show it's live right or not?
or what settings do i turn it to on the tester meter thing?
still waiting for the battery to fully charge so no particular rush, but surely someone's had this happen before?
how do i do this?
how do i do this?
how do i do this?
Regards Doug.
I thought theres two live feeds to an amp. your main live then your remote (normally a blue wire)that goes from head unit to amp to switch the amp on/off when the head unit is turned on/off. I have had this before where the remote has been wired to a permanant live. That willl drain your battery
I thought theres two live feeds to an amp. your main live then your remote (normally a blue wire)that goes from head unit to amp to switch the amp on/off when the head unit is turned on/off. I have had this before where the remote has been wired to a permanant live. That will drain your battery
But did you put the meter in series with the positive lead, or the amp's own power connection?
It should have been the latter, if the former this won't tell you.
Tbh 11.4V is not very good, a good reading will be 12V plus.
You can't use a test light as this simply will light if there is power, which is obviously true of the battery.
You need a meter set to DCA to measure the draw.
Martin
Martin
cossie fan (unluckerly)
put an amp clamp around the negative terminal cable on the battery then see how many amps are drawing you can even work out how long it will take for that amp drain to drain your battery i.e amp hour rating / amp drain = hours it will take to drain / 24 = days it will take! ( 520 amp hour battery with a 2.4 amp drain will take 217 hours to drain so 9 days! )
as for an amp clamp, was going to buy one but there are so many out there to chose from, and i don't want to get one for a tenner thats shite if i need to spend Ł60 on one that's going to do the job
plenty of sites have said the cheap ones are not worth having, so if someone has a recommendation?
did you check for a drain at the battery? you really need an amp clamp there could be something else drawing currant all the time draining it which is why you should test at the battery that way if there is you can un plug things or pull fuses till the drain gos so you know whats doing it! have you tested the battery maybe its fucked just because it has a charge in it dose not mean its good! it may have a dead cell in it causing it to lose its charge!
it's a new battery, only got it on saturday and on sunday the cars flat again ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
kill switch was my other option but it's going to be an arse to open the bonnet every time to turn it on and off again![Wall](https://passionford.com/forum/images/smilies/wall.gif)
unless someone does a remote kill switch i can fit under the dash somewhere?
remove earth cable and put mm on 10a and put cable in 10a, connect between ground and battery and check drain. make sure everything is off though, car doors, bonnet etc shut, alarm on etc and check drain once its fully asleep.
just read this if ur unsure
http://wzeu.search-results.com/r?t=p...battery-drains
followed that advise before, no drain so no pulling of the fuses required
but the battery just changes if the amp is plugged in or not
don't really want to risk going out in the car and then the battery being dead
might just invest in a jump pack and leave it on charge in the fag lighter every time i go out
How quickly is your battery going flat?? Seeing as you're not finding a drain but obviously suspec the amp, why not just disconnect the amp and see if it goes flat in its usual time??
Fresh onion..
As all ready mentioned the best way to get a correct reading is with an amp clamp round the negative lead, I personally wouldn't do it any other way... ajamesc this man speaks sense
http://www.digital-meters.com/epages...g/Clamp_Meters
are these the sorts of things i should be looking at then?
saying that i got a couple not sure if ac dc or bonjovi
Finally started to get to the bottom of this and even with the battery disconnected the clamp meter is showing a reading of 1.98a ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
So I spent a long time last night trying to figure out what was wrong and it seems that the culprit is the alarm as the stereo amp doesn't do anything (put the clamp meter on that and no losses there) so what else could it be?
I've already discovered that the c/locking was rung from the power folding mirror relay so I've Fu kerf at out of the equation
how can it draw 1.9 amps with the battery disconected? there would be no power for it to draw from? you will just have to disconect things or pull fuses till the amp drain gos so you have an idea whats doing it! my alarm drains my battery if i dont use the car say after a week it wont start so i have to leave it on a trickle charger
Gary Krishna
Did you zero the amp clamp before you fitted round the cables? They need to be reset to zero.
If you look at it, there should be a reset button. Hold the clamp part against the cable/s you wish to test (not around just against), press reset and then put the clamp round the cable. This should give you the correct reading.
I may be going to the middlesex meet tonight mate so if you are going, I can show you how to check it if you want?
is that 1.9 amps with the clamp round the battery negative with every thing switched off i.e doors shut aswell so no interior lights are on? also it dosent have an under bonnet light dose it also what amp hour rating is your battery?
thats with the battery disconnected mate, so i'm sure i'm failing at something ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
well, i say "disconnected", what i really mean to say is "the battery cut off in the off position with the key removed so there shouldn't be any drain"
right lol then your cut off isent working or isent wired in right lol theres no way you can have a drain with the battery disconected as there is no power circuit to drain from!
