fitted. supra diff into a sierra beam.
#41
I've seen the ones using the ford 8.8 on merkurs
http://www.merkurtech.com/merkurtech...dg88kit010.jpg
http://www.merkurtech.com/merkurtech...dg88kit013.jpg
http://www.merkurtech.com/merkurtech...dg88kit012.jpg
#43
There are plenty of rear diffs you could use. But it's whether the ratio's are suitable.
M3 ? M5, Nissan 300, Nissan 200 ?, rwd Skyline or perhaps even 4wd Skyline rear, Supra. All should be relatively easily available locally.
8.8" whilst nice, would need to be sourced from the US. Dont imagine there are many over here.
#44
1st to 200 without NOS
#45
Only concern there is, they readily upgrade to a 9" etc. The diff unit itself is weak, as are the output stubs and shafts.
Although obviously it is fitted to a larger heavier car and with an engine with more torque ( well, than some cars )
With a diff upgrade and output stubs/flanges, then I'm sure it would be very strong. But after the cost of that, you'd have already bought a stronger standard unit.
#49
have you got the small or big case diff ?
my small case will be for sale maybe next year when i go big case and radials, if you might be interested in it ? carbonetics 1.5 way, leaves 2 thick equal blackys every time
JK12
33
26-04-2021 12:09 PM
