Who's the S2 Doctor???
Legend
I basically had to get somewhere in a hurry last night and gave it a bit of chat along some A roads onto a motorway [seriously wasn't speeding, this isn't a heroic tale of daring, just accelerating to the speed limit quickly]
Anyway, I lost power coming off the slip road and pulled in, the car wouldn't idle and cut out, thought I'd popped something off round the oil breather so lifted the bonnet only to see the exhaust manifold and turbo housing glowing like the lighter in a car [I've seen Yums do this, but not the poxy bean tins ]
I let it cool down for 10 minutes and it started fine, no puffs of smoke, but seemed to labour a bit under gentle acceleration.
Tried it this morning and SOUNDs like there's a major blow on the manifold, still no smoke from the turbo
It's still labouring under acceleration but when I got nearer home I thought I'd check to see what it's boosting at and it's still holding 14 PSi [just as Karl Norris set it up at ]
but feels like its holding back?
Does this sound the symptoms of an exhaust manifold leakage? maybe a fooked gasket? Is there a gasket between the manifold and the turbo? I can't see it to well?
Anything I should check for specifically?
CheeRS
CheeRS
a std rst will glow if u give it some.
No gasket between turbo and manfold. Sounds more likey like the exhaust to turbo - these can come loose. Try undoing it and re fitting it.
#1 in Spelling Club
My main concern there is that once the car cut out, you let it cool.
You really should have started it again to get the oil circulating as it would have sat quite happily in the Cherry Red Turbo cooking away and is probably now all frothy.
I personally would remove the Turbo and refit the Manifold with a new gasket and all new studs/washers/nuts if it hasn't been done before. Make sure everything is tight, including the 4 nuts that fix the Turbo to the Manifold and that the 5 nuts that hold the Cast Elbow on are all tight too.
Are you sure the blow is coming from there?
Legend
cheers for the advice it's much appreciated I'll have a go at what you said later in the week
