Staged Turbos (no, NOT sequential turbos)
#42
DEYTUKURJERBS
Subaru running it? Ive seen twin turbo legacys etc that the writeups about them claim its a staged setup like this, but its not at all, its a sequential setup, ie the turbos DONT blow thru each other.
If its really compouund charging this scooby id love to know more...
#43
Steve, years back I was talking to Geoff Kershaw (MD of Turbo Technics), and he told me that he was working on a "twin" turbo set-up called "K Gate".....
Cannot recall how it was done, but he drew out a letter "K" as proceeded to explain how one turbo was linked to the other to produce a combined out greater than both turbo's could produce if linked in any other way........went waaaay over my head THB....wonder if it was the same thing as in your pics ???
#44
Originally Posted by Itsmeagain
no, sequential setups are different, and vary depending on the application, but NONE of them blow thru another turbo, they all blow into a common pipe after the turbos.
Thats the difference with this setup, its NOT made to decrease lag or whatever like sequential setups, this is to be able to do extreme boost levels that isnt possible with a single turbo.
Or is it just a case of the little one spools up first (cos it's smaller) and the bigger ones spools up later (cos it's bigger) but it just uses normal ambient air like the little one does?
spose that explains why you see Skylines and Supra's with twin button filters - D'OH!!!
So the "sequential" bit is just cos the spool up in sequence?
Think I got it now
#46
DEYTUKURJERBS
Doug- Nope, thats a sequential type setup they designed for cossies years back, IIRC Tony@Turbosystems still has the bits to use it.
Basicly was a twin sequential setup running like a T25 and a T4, the gate put all ex gas to the T25 till a certain pressure then an actuator type thing moved the gate to bring the T4 into play
IIRC it worked, but the price and room it takes up outweighed the advantages it gave.
Thats the thing see, there sooo many examples of sequential type setups around, inc some that share all the ex gas like the staged turbos do, but NO detailed info on setups where turbos blow thru each other.
Basiclly what i posted is a common mod on modified Cummins Diesels that often run 100psi+ boost, twin and tripple setups
But info on exactly how it works on the net? Feck all
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
#48
DEYTUKURJERBS
Dont forget, the smaller turbo on sequential setups dont feed the bigger turbo boost, its the exhaust gas created by the power and higher RPM that spools the 2nd one up
Staged or "compound" turbo charging is using one turbo to spool another and so on...... Interesting...
Interesting, but no details yet, there is meant to be details of the setup in some turbo books, but i aint got em
JK12
33
26-04-2021 12:09 PM
