Starting to order parts for my new engine (zvh) help please :)
Needs Beer Tokens.....
Hi guys after much umming and arring about which engine to go for, and driving my mates 203bhp FRST i have decided a 200bhp engine would be acceptable for my needs as it is a nice useable power IMO.
I have decided to therefore go 2.1 ZVH turbo so i dont screw the life out of the cvh as i use the car hard daily and from what i have seen with my mates is they eat gearboxes and headgaskets .
What im trying to find out is what will be needed and what is missing from my list
So im assuming:
2.0 bottom end
Decomp plate?
do i remember something about a different cambelt pulley and sump?
Metal head gasket
Im on OFAB management already
Beige injectors and a 195 chip
i have a stage 2 t3 and big front mount which i beleive will be more then enough for the job, the main aim is to have reliable 200bhp without parts being on the limit all the time, yet still having the potential to up the power abit if i ever get bored in the future.
Anything i have missed/and or got wrong? and if anyone could let me know what pulley/sump i need to run would be very greatfull
So im assuming:
2.0 bottom end
Decomp plate?
Metal head gasket
Skint Passionford User
Sump, oil pickup and dipstick off an 1800 zetec escort.
Std skimmed pistons if you dont want to run more than 14psi or forged if you do
1300 cvh cambelt tensioner, 1600 cvh bottom pulley
and get it setup properly
Thats what I used to build the 1800 bottom end that I ended up selling because I changed spec again Made decent power (about 240?) I believe after the lad who bought it got it setup and dynoed. Took 0.5mm off the top of std 1.8 silvertop pistons
http://www.quantums.info/zvh.htm
loads of bumf on there, you can use c20xe or let pistons cant remember which.
Only thing im thinking is with zetec, it seems people are spending alot of time and cash to get them where they want them and seem to be mainly trying to gain 300bhp ish when im literally after 200-230ish bhp, which as said IMO is more driveable.
Being brutally honest if you're only wanting 200bhp mate that's very easily achievable staying with the 1.6 and as long as the engine's built by someone who knows what they're doing and more importantly is mapped properly it will be 100% reliable
Depending on the spec of the engine and what turbo you use you won't need to run mega boost either which might save your gearboxes
I'd get an unburstable spec cvh with aftermarket management with about 220 bhp and really decent boost control and map the boost so it won't over stress the gearbox. Will be a great car to thrash then
Just ordered a 195 chip and have the beiges allready so once the chips fitted i shall stick it on the rollers and see where we are on the cvh im running then
Ł500 for a ZVH build?? what u building it with?? chewing gum!
i built a ZVH,
what about having back of head welded up to use zetec gasket? or you guna use a cvh one?
what about pistons?? machine work
tensioner
for Ł500 its guna be a right nail of an engine!
i built a ZVH,
tensioner
Super Moderator
agreed .. i was running 22 psi on my old 1.6 cvh .. setup by madevelopments went like stink... upset a few cossie owners on the track too ..
.5 ovebore,
40tho skimm on the pistons,
grs intercooler and rad,
standard management,
standard head gasket,
rebuilt gearbox from ford,
new turbo (mad specced)
not expensive to do .... was very reliable, drove to the rs trackdays and drove home again
2.1 zvh
Hi my s2 turbo is a 2.1 zvh and running 300 bhp at wheels and is reliable as any other rs turbo never misses a beat Spec of car
2 litre zetec black top bottom end bored out to a 2.1
forged low comp pistons
steel H section con rods
stage 3 burton power big valve ported head
piper T2 cam shaft
turbo technics Stage 3 t34 turbo with cosworth exhaust housing
pace charge pipe
pace front mounted intercooler
Alloy radiator
twin ken lowe fans
low temp fan switch
full samco hose kit
efi conversion
Ofab management with custom map
beige Injectors
cosworth fuel pump
mongoose turbo back exhaust
full 90 spec body kit and spoiler
90 spec interior
cosworth 3 spoke steering wheel
nomad boost guage
17" rs 7 spoke wheels
koni adjustable suspension
polybushed front end
Escort cosworth front brakes
300mm brake disks
uprated paddle Clutch
rebuilt gearbox with big case bearings
delocked doors
delocked boot lid
Scorpian alarm
piper T2 cam shaft
pace charge pipe
Alloy radiator
twin ken lowe fans
low temp fan switch
full samco hose kit
efi conversion
beige Injectors
cosworth fuel pump
90 spec interior
nomad boost guage
300mm brake disks
delocked doors
delocked boot lid
Scorpian alarm
Balls Deep!
piper T2 cam shaft
pace charge pipe
Alloy radiator
twin ken lowe fans
low temp fan switch
full samco hose kit
efi conversion
beige Injectors
cosworth fuel pump
90 spec interior
nomad boost guage
300mm brake disks
delocked doors
delocked boot lid
Scorpian alarm
piper T2 cam shaft
pace charge pipe
Alloy radiator
twin ken lowe fans
low temp fan switch
full samco hose kit
efi conversion
beige Injectors
cosworth fuel pump
90 spec interior
nomad boost guage
300mm brake disks
delocked doors
delocked boot lid
Scorpian alarm
For budget build use st170 bottom end with thick headgasket like felpro and sitech have a few built all running between 250/300bhp with no problems
You can buy a complete st170 engine around 500/600 quid.
Then the head will sell for half that , then the conversion bits are around Ł300 plus Ł120 worth of machine work.
You need to mod the sump, which crazycage has done,
Honestly mate i went zvh and always regretted it, just go full zetec turbo! you can spend half the money and see a much better bhp!!! if you only want 200bhp thats cool but take in mind a full zetec turbo will do 200bhp with ease... and for a lot longer then a zvh!
muz
16-08-2015 12:57 PM
Zoggon
10-08-2015 10:39 AM
CabrioTurbo
01-08-2015 11:04 AM
