fan stays on even when cold?
hi my mk1 frs fan has just today started staying on all the time from cold.
any ideas as to why its doing this?
also when coming to a stop car trys cuting out and rpm is dropping to 5-6k.
any help would be brilliant
thanks kieran
thanks kieran
Sounds like it could be a short in the wiring or more likely the cooling fan senser has failed, if your car has a separate cooling fan sensor switch or does the ecu control it?
i have noticed tha it does come on every so ofen on start up but always then goes off.
the prolem is it stays on the whole time the cars running. temps are around 97c so could poss be fan sensor?
thanks kieran
thanks kieran
SMILER258
28-09-2015 09:04 AM
